388.9_2 - Router Internet Speed Test Not Working
iamjayder
Anyone experiencing an issue where the internet speed test inside the router is not working for this version? When you click the Go button nothing happens. I just did a fresh firmware recovery using the Asus Firmware Recovery app (and did factory reset also) and noticed that this is not working. Even in the Asus router app in Android this is not working. Other than this, there are no issues with the wifi. My router is an Asus RT-AX88U btw.
Can you please remove "Release" tag as you don't release anything!
Just an FYI, the Asus router app is not supported by Asus-Merlin firmware. While it may access the router and may work to configure certain features, it is not officially supported due to various Asus-Merlin firmware elements that are not found in the stock Asus firmware.
Does a speed test work using a web browser?
And why did you do a firmware recovery using the Asus firmware recovery app? What problem or issue were you having prior that necessitated the use of the Asus firmware recovery app?
I used the recovery program to have a clean install of Merlin. I was testing using both web browser and Asus router app. Both are not working. But when I was in version 388.9 everything was working fine (both web browser and Asus Router app).
Works fine here, 388.9_2 and also RT-AX88U, so it may be something specific to your environment.
Same here! Though a first the page didn't load completely under the latest Chrome, a quick reload brought it up and it works for me as well
@iamjayder do you have skynet installed? If so which blocklist are you using?
Maybe I will try to restore the stock firmware and dirty flash Merlin right after and reset to factory defaults. I'll see if it works.
Thanks!
