5Ghz GUEST Network not propagating to AiMesh nodes?
In this image, a 2.4 GHz IoT is already created on the left, VLAN 53, therefore the yellow warning your 2.4 GHz limit has been reached...
Thanks for the input, but TBH I don’t think there’s anything I can add to this thread. I’ve done my testing, I’ve asked ASUS, @bennor has provided ASUS FAQ on it.
My experience is that you can successfully propagate only two (2) guest networks per band to each AiMesh node when you mix 3006 firmware router with 3004 firmware node. Using all 3006 firmware devices, the limitation goes away. One workaround to provide more guest network coverage is to select either 2.4 or 5 GHz for a particular guest network, not both — this makes a lot of sense for IoT guest networks since the majority of IoT devices support 2.4 GHz only.
Just to drill down into this a bit further, as I only see one per band, due I believe to having Smart Connect enabled or trying a dual band SSID, which seems to occupy both.
Smart Connect only affects primary network -- primary network is automatically pushed to all nodes. You are correct though that dual band SSID for guest network does indeed occupy both slots.
Smart Connect only affects primary network -- primary networkis automatically pushed to all nodes.
Ah, yes, you’re absolutely correct there.
Yep, and this is the exact point; if you want two you have to separate the bands.
Two per band should work.
Just revisited my earlier note above, which remains the case from my observations
despite GNP allowing you to select the two band combo (2.4/5), only one of them actually gets propagated to the node; this is the limitation. It doesn't say which band, but for me it seemed to be the 5Ghz if you select both.”
