##### IEEE 802.11ax related configuration #####################################
#ieee80211ax: Whether IEEE 802.11ax (HE) is enabled
# 0 = disabled (default)
# 1 = enabled
#ieee80211ax=1
# disable_11ax: Boolean (0/1) to disable HE for a specific BSS
#disable_11ax=0
#he_su_beamformer: HE single user beamformer support
# 0 = not supported (default)
# 1 = supported
#he_su_beamformer=1
#he_su_beamformee: HE single user beamformee support
# 1 = supported
#he_su_beamformee=1
#he_mu_beamformer: HE multiple user beamformer support
# 1 = supported
#he_mu_beamformer=1
# he_bss_color: BSS color (1-63)
#he_bss_color=1
# he_bss_color_partial: BSS color AID equation
#he_bss_color_partial=0
#he_default_pe_duration: The duration of PE field in an HE PPDU in us
# Possible values are 0 us (default), 4 us, 8 us, 12 us, and 16 us
#he_default_pe_duration=0
#he_twt_required: Whether TWT is required
# 0 = not required (default)
# 1 = required
#he_twt_required=0
#he_twt_responder: Whether TWT (HE) responder is enabled
# 0 = disabled
# 1 = enabled if supported by the driver (default)
#he_twt_responder=1
#he_rts_threshold: Duration of STA transmission
# 0 = not set (default)
# unsigned integer = duration in units of 16 us
#he_rts_threshold=0
#he_er_su_disable: Disable 242-tone HE ER SU PPDU reception by the AP
# 0 = enable reception (default)
# 1 = disable reception
#he_er_su_disable=0
# HE operating channel information; see matching vht_* parameters for details.
# he_oper_centr_freq_seg0_idx field is used to indicate center frequency of 80
# and 160 MHz bandwidth operation. In 80+80 MHz operation, it is the center
# frequency of the lower frequency segment. he_oper_centr_freq_seg1_idx field
# is used only with 80+80 MHz bandwidth operation and it is used to transmit
# the center frequency of the second segment.
# On the 6 GHz band the center freq calculation starts from 5.950 GHz offset.
# For example idx=3 would result in 5965 MHz center frequency. In addition,
# he_oper_chwidth is ignored, and the channel width is derived from the
# configured operating class or center frequency indexes (see
# IEEE P802.11ax/D6.1 Annex E, Table E-4).
#he_oper_chwidth
#he_oper_centr_freq_seg0_idx
#he_oper_centr_freq_seg1_idx
#he_basic_mcs_nss_set: Basic NSS/MCS set
# 16-bit combination of 2-bit values of Max HE-MCS For 1..8 SS; each 2-bit
# value having following meaning:
# 0 = HE-MCS 0-7, 1 = HE-MCS 0-9, 2 = HE-MCS 0-11, 3 = not supported
#he_mu_edca_qos_info_param_count
#he_mu_edca_qos_info_q_ack
#he_mu_edca_qos_info_queue_request=1
#he_mu_edca_qos_info_txop_request
#he_mu_edca_ac_be_aifsn=0
#he_mu_edca_ac_be_ecwmin=15
#he_mu_edca_ac_be_ecwmax=15
#he_mu_edca_ac_be_timer=255
#he_mu_edca_ac_bk_aifsn=0
#he_mu_edca_ac_bk_aci=1
#he_mu_edca_ac_bk_ecwmin=15
#he_mu_edca_ac_bk_ecwmax=15
#he_mu_edca_ac_bk_timer=255
#he_mu_edca_ac_vi_ecwmin=15
#he_mu_edca_ac_vi_ecwmax=15
#he_mu_edca_ac_vi_aifsn=0
#he_mu_edca_ac_vi_aci=2
#he_mu_edca_ac_vi_timer=255
#he_mu_edca_ac_vo_aifsn=0
#he_mu_edca_ac_vo_aci=3
#he_mu_edca_ac_vo_ecwmin=15
#he_mu_edca_ac_vo_ecwmax=15
#he_mu_edca_ac_vo_timer=255
# Spatial Reuse Parameter Set
# SR Control field value
# B0 = PSR Disallowed
# B1 = Non-SRG OBSS PD SR Disallowed
# B2 = Non-SRG Offset Present
# B3 = SRG Information Present
# B4 = HESIGA_Spatial_reuse_value15_allowed
#he_spr_sr_control
# Non-SRG OBSS PD Max Offset (included if he_spr_sr_control B2=1)
#he_spr_non_srg_obss_pd_max_offset
# SRG OBSS PD Min Offset (included if he_spr_sr_control B3=1)
#he_spr_srg_obss_pd_min_offset
# SRG OBSS PD Max Offset (included if he_spr_sr_control B3=1)
#he_spr_srg_obss_pd_max_offset
# SPR SRG BSS Color (included if he_spr_sr_control B3=1)
# This config represents SRG BSS Color Bitmap field of Spatial Reuse Parameter
# Set element that indicates the BSS color values used by members of the
# SRG of which the transmitting STA is a member. The value is in range of 0-63.
#he_spr_srg_bss_colors=1 2 10 63
# SPR SRG Partial BSSID (included if he_spr_sr_control B3=1)
# This config represents SRG Partial BSSID Bitmap field of Spatial Reuse
# Parameter Set element that indicates the Partial BSSID values used by members
# of the SRG of which the transmitting STA is a member. The value range
# corresponds to one of the 64 possible values of BSSID[39:44], where the lowest
# numbered bit corresponds to Partial BSSID value 0 and the highest numbered bit
# corresponds to Partial BSSID value 63.
#he_spr_srg_partial_bssid=0 1 3 63
#he_6ghz_max_mpdu: Maximum MPDU Length of HE 6 GHz band capabilities.
# Indicates maximum MPDU length
# 0 = 3895 octets
# 1 = 7991 octets
# 2 = 11454 octets (default)
#he_6ghz_max_mpdu=2
#he_6ghz_max_ampdu_len_exp: Maximum A-MPDU Length Exponent of HE 6 GHz band
# capabilities. Indicates the maximum length of A-MPDU pre-EOF padding that
# the STA can receive. This field is an integer in the range of 0 to 7.
# The length defined by this field is equal to
# 2 pow(13 + Maximum A-MPDU Length Exponent) -1 octets
# 0 = AMPDU length of 8k
# 1 = AMPDU length of 16k
# 2 = AMPDU length of 32k
# 3 = AMPDU length of 65k
# 4 = AMPDU length of 131k
# 5 = AMPDU length of 262k
# 6 = AMPDU length of 524k
# 7 = AMPDU length of 1048k (default)
#he_6ghz_max_ampdu_len_exp=7
#he_6ghz_rx_ant_pat: Rx Antenna Pattern Consistency of HE 6 GHz capability.
# Indicates the possibility of Rx antenna pattern change
# 0 = Rx antenna pattern might change during the lifetime of an association
# 1 = Rx antenna pattern does not change during the lifetime of an association
# (default)
#he_6ghz_rx_ant_pat=1
#he_6ghz_tx_ant_pat: Tx Antenna Pattern Consistency of HE 6 GHz capability.
# Indicates the possibility of Tx antenna pattern change
# 0 = Tx antenna pattern might change during the lifetime of an association
# 1 = Tx antenna pattern does not change during the lifetime of an association
# (default)
#he_6ghz_tx_ant_pat=1
# 6 GHz Access Point type
# This config is to set the 6 GHz Access Point type. Possible options are:
# 0 = Indoor AP (default)
# 1 = Standard Power AP
# This has no impact for operation on other bands.
#he_6ghz_reg_pwr_type=0
# Unsolicited broadcast Probe Response transmission settings
# This is for the 6 GHz band only. If the interval is set to a non-zero value,
# the AP schedules unsolicited broadcast Probe Response frames to be
# transmitted for in-band discovery. Refer to
# IEEE P802.11ax/D8.0 26.17.2.3.2, AP behavior for fast passive scanning.
# Valid range: 0..20 TUs; default is 0 (disabled)
#unsol_bcast_probe_resp_interval=0
