AB-Solution Question
Kim Puleston
Hey all,
I installed AB-Solution on my AC88U Router and all went well :). The question I have is how do you access the logs to see what it is blocking ? I ask as I still seem to see ads on various websites I am visiting and I want to make sure everything is working as it should. When I first went to install it, I was warned that I had DNS entries for my LAN, which I removed and I re-ran the setup and no warnings come up so I can only assume it setup ok.
Just so its known I went for the Large Install to get as many hosts as I could.
Thanks.
Did you reboot the router afterwards? Did you reboot your clients?
I may have been premature as it seems to be functioning, now I need to add a website to a whitelist as the Adblock kills some of the websites functionality. I have had a little look but unsure as to how I add an exception ?
Ignore me , I have used WinSCP and found the whitelist file and made some editions to it using the WinSCP editor. I assume that is ok to do with existing files, I know its recommended to use Notepad++ for new files.
Don't take it personal.
But next time, please post in the AB-Solution thread and don't start a new one.
AB-Solution dominates the front page enough, no other threads are needed.
Thanks.
Appologies, I will not make a seperate thread next time. I may be doing something wrong, but when adding domains to the whitelist, they still seem to get blocked and I am not just referring to the ads but the entire site wont load.
I have added the sites I want to whitelist according to the instructions but still to no avail, what am I doing wrong ?
Cheers.
