AC-3200 WAN Slows after time 384.13_10
wessty1984
This isn't a major issue but wanted to see if there is anything I can look at to improve the router. Basically I have an AC-3200 that was just factory reset and re-configured. Currently running 1GB down 50 up cable internet. Everything is looking good and I'm probably maxing out the 5 GHz Wifi at 600 Mbps. After a while (less than 1 day) the speeds seem to slow down and stick on 330 Mbps, even on Ethernet. A reboot of the router or a restart of the internet connection in scMerlin gets it back to normal.
Is there some setting I have wrong or if possible can script something with ScMerlin to restart that internet connection every few hours? Thanks to anyone that has any ideas or suggestions.
