AC-5300 Problem
Jasso
Just acquired an AC-5300, did factory reset and get download of 13 Meg against 77 Meg with RT-N66u.
Checked all the settings and seem OK to me, repeated reset and setup twice more with no improvement.
Stuck my trusty old RT-N66U back on and right back to 77/17, anyone with solution please?
Wired or wireless connection? What type of internet gateway device to you have, cable modem, ADSL, etc.?
At least now you know where to look for the problem. If you have a WiFi connection "profile" on your client device delete/forget it and recreate it.
Sorted, after much tinkering in setup I had a look at speedtest on my iPhone and it was 60-70 Meg which is better than normal.
Turned out to be a driver problem on the laptop, after finding and installing new driver speed now up to 78/17 so all good.
Thanks for your time
