I am using Merlin 386.7_2 on a RT-AC5300. trying to setup dual WAN with fallback.
As long as the primary WAN is up all works. If I manually reconnect the Prim WAN port to my secondary WAN gateway this works as well (just to check connectivity).
First issue:
Now first problem if you setup dual wan failover the secondary wan port stay in cold standby. A failover does not work. Manually disabling and enabling internet on secondary WAN brings it up to hot standby.
Should it not always be hot standby? Note using DHCP on both connections.
Second issue:
If it failover to secondary WAN no traffic is working and it states not internet connection (but there is secondary WAN is working wo issues).
Only after fallback WAN traffic comes back to normal.
What is the wanted designed behaviour for case 1?
Someone who got the failover and fallback working? any tipps?
thanks in advance
First issue:
Second issue:
thanks in advance
