AC56U - No IPv6? [AP-Mode]
Meecrob
I'm using latest Asuswrt-Merlin on my AC56U, which is set to work in Access Point-Mode. DCHP IPv4 & DHCP IPv6 is run by my Router, not the AC56U. The AC56U won't get an IPv6 from my router, but clients are. Mabye someone can help me to get the AC56 an IPv6 address!
ifconfig says
br0        Link encap:Ethernet  HWaddr AC:22:0B:25:02:70
           inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
           RX packets:164782635 errors:0 dropped:0 overruns:0 frame:0
           TX packets:216218621 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:0
           RX bytes:135494313971 (126.1 GiB)  TX bytes:264019181813 (245.8 GiB)
eth0       Link encap:Ethernet  HWaddr AC:22:0B:25:02:70
           RX packets:169762818 errors:0 dropped:0 overruns:0 frame:0
           TX packets:214538714 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:1000
           RX bytes:2827670897 (2.6 GiB)  TX bytes:3996775882 (3.7 GiB)
           Interrupt:179 Base address:0x4000
eth1       Link encap:Ethernet  HWaddr AC:22:0B:25:02:70
           RX packets:14698980 errors:0 dropped:0 overruns:0 frame:7934633
           TX packets:23833630 errors:2736 dropped:0 overruns:0 carrier:0
           RX bytes:1500561435 (1.3 GiB)  TX bytes:2138398317 (1.9 GiB)
           Interrupt:163
eth2       Link encap:Ethernet  HWaddr AC:22:0B:25:02:74
           RX packets:0 errors:0 dropped:0 overruns:0 frame:0
           TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
           Interrupt:169
lo         Link encap:Local Loopback
           inet addr:127.0.0.1  Mask:255.0.0.0
           UP LOOPBACK RUNNING MULTICAST  MTU:16436  Metric:1
           RX packets:489284 errors:0 dropped:0 overruns:0 frame:0
           TX packets:489284 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:93747872 (89.4 MiB)  TX bytes:93747872 (89.4 MiB)
vlan1      Link encap:Ethernet  HWaddr AC:22:0B:25:02:70
           RX packets:157478827 errors:0 dropped:0 overruns:0 frame:0
           TX packets:206843947 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:135636022174 (126.3 GiB)  TX bytes:252114452480 (234.7 GiB)
IPconfig on my PC, which is connected to the AC56U through cable, is getting this:
Ethernet-Adapter Ethernet:
   Verbindungsspezifisches DNS-Suffix:
   IPv6-Adresse. . . . . . . . . . . : 2a02:908:d915:f300:6da0:95da:3088:cf8c
   Tempor„re IPv6-Adresse. . . . . . : 2a02:908:d915:f300:26:5b99:8dec:4ba0
   IPv6-Adresse. . . . . . . . . . . : 4006:1027:c0a8:17e:6da0:95da:3088:cf8c
   Verbindungslokale IPv6-Adresse  . : fe80::6da0:95da:3088:cf8c%3
   IPv4-Adresse  . . . . . . . . . . : 192.168.1.10
   Subnetzmaske  . . . . . . . . . . : 255.255.255.0
   Standardgateway . . . . . . . . . : fe80::2665:11ff:fe5e:cdb7%3
                                       192.168.1.1
