Dropouts on ASUS RT-AX86U
kram66
I've had my RT-AX86U for about 18 months and has been working just fine, but over the past month I've experienced a number of dropouts.
I've contacted my ISP who were less than helpful, so I've started my own investigation and wondering if anybody had the same experience.
I've got a RT-AX86U using Merlin firmware 3004.388.8_2
running a ping to google.com, I would see frequent timeouts, then looked at the WAN interface which showed the following issues
eth0 Link encap:Ethernet HWaddr 3C:7C:3F:6B:F1:D0
inet addr:x.x.x Bcast:x.x.x.x Mask:255.255.192.0
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:2125002 errors:0 dropped:0 overruns:0 frame:0
TX packets:129675131 errors:0 dropped:255677 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1773519654 (1.6 GiB) TX bytes:141698759874 (131.9 GiB)
Looking at the logs, I did notice a few issues, but not sure how to address it. First, I've shutdown my OpenVPN server to see if that helps. I'm also using my older ASUS RT-AX68U as a Mesh but it seems to be working ok.
This is just a part of the syslog
Oct 25 08:12:29 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 5C:CF:7F:95:E8:C0, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Oct 25 08:12:29 wlceventd: wlceventd_proc_event(685): eth6: Auth 5C:CF:7F:95:E8:C0, status: Successful (0), rssi:0
Oct 25 08:12:29 wlceventd: wlceventd_proc_event(722): eth6: Assoc 5C:CF:7F:95:E8:C0, status: Successful (0), rssi:-74
Oct 25 08:12:40 kernel: 2C:AA:8E:12:BF:6C not mesh client, can't delete it
Oct 25 08:12:40 kernel: 46:7A:75:CB:D5:6B not mesh client, can't delete it
Oct 25 08:12:40 kernel: 14:7B:AC:AE:A8:CE not exist in UDB, can't delete it
Oct 25 08:12:40 kernel: B2:E1:1F:30:AD:C6 not mesh client, can't delete it
Oct 25 08:12:52 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link Up at 1000 mbps full duplex
Oct 25 08:12:56 WAN_Connection: WAN(0) link up.
Oct 25 08:12:56 rc_service: wanduck 1479:notify_rc restart_wan_if 0
Oct 25 08:12:56 ovpn-server2[2358]: event_wait : Interrupted system call (fd=-1,code=4)
Oct 25 08:12:56 ovpn-server2[2358]: Closing TUN/TAP interface
Oct 25 08:12:56 ovpn-server2[2358]: /usr/sbin/ip addr del dev tun22 10.16.0.1/24
Oct 25 08:12:56 ovpn-server2[2358]: ovpn-down 2 server tun22 1500 0 10.16.0.1 255.255.255.0 init
Oct 25 08:12:56 ovpn-server2[2358]: PLUGIN_CLOSE: /usr/lib/openvpn-plugin-auth-pam.so
Oct 25 08:12:56 ovpn-server2[2358]: PLUGIN AUTH-PAM: Error signaling background process to exit: Connection refused (errno=111)
Oct 25 08:12:56 ovpn-server2[2358]: SIGTERM[hard,] received, process exiting
Oct 25 08:12:56 kernel: 2C:AA:8E:12:BF:6C not mesh client, can't update it's ip
Is there anything I can try or a setting I've missed?
You need to look further back in the log for the "WAN(0) link down" messages and see if there's any other relevant messages around that time.
Try replacing the ethernet cable between the router and modem (or ONT). Also check the logs on the modem.
There is nothing in the logs that indicates that WAN(0) is down, in fact I can't find any reference to WAN at all.
I've replaced the cable and I've also turned off OpenVPN to see if that resolves it.
Constantly get dropped packets, no idea if it's the router or my ISP box, how do I tell where the problem is?
RX packets:2061413 errors:0 dropped:0 overruns:0 frame:0
TX packets:329410389 errors:0 dropped:1210296 overruns:0 carrier:0
RX bytes:2387486538 (2.2 GiB) TX bytes:338093738186 (314.8 GiB)
Mem: 457312K used, 476652K free, 4292K shrd, 0K buff, 39232K cached
CPU: 0.0% usr 4.7% sys 0.0% nic 95.2% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 1.01 1.05 1.07 3/191 21408
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
1517 1 adminx S 41784 4.4 2 0.0 nt_center
1705 1704 adminx S 35592 3.8 0 0.0 /usr/lib/ipsec/charon --use-syslog
1847 1 adminx S 22428 2.4 1 0.0 cfg_server
1878 1 adminx S 21284 2.2 0 0.0 amas_lib
1817 1 adminx S 19452 2.0 0 0.0 conn_diag
1787 1 adminx S 18960 2.0 3 0.0 mastiff
345 1 adminx S 18532 1.9 3 0.0 /bin/swmdk
3495 1 adminx S < 18424 1.9 1 0.0 dcd -i 3600 -p 43200 -b -d /tmp/bw dpi/
1842 1817 adminx R 18332 1.9 1 0.0 amas_portstatus
1815 1 adminx S 18232 1.9 0 0.0 roamast
3504 1 adminx S 17656 1.8 3 0.0 wred -B
1784 1 adminx S 17060 1.8 0 0.0 /usr/sbin/lighttpd -f /tmp/lighttp d.conf -D
1506 1 adminx S 15260 1.6 3 0.0 /sbin/netool
1770 1 adminx S 15004 1.6 1 0.0 networkmap --bootwait
1 0 adminx S 14332 1.5 3 0.0 /sbin/init
1504 1 adminx S 14036 1.5 1 0.0 nt_monitor
2373 1 adminx S 13868 1.4 3 0.0 /usr/sbin/lighttpd-arpping -f br0
1645 1 adminx S 13212 1.4 3 0.0 watchdog
1647 1 adminx S 13212 1.4 2 0.0 alt_watchdog
1479 1 adminx S 13212 1.4 2 0.0 /sbin/wanduck
1650 1 adminx S 13212 1.4 1 0.0 sw_devled
3549 1 adminx S 13212 1.4 1 0.0 bwdpi_wred_alive
2195 1 adminx S 13212 1.4 3 0.0 usbled
1655 1 adminx S 13212 1.4 2 0.0 amas_lanctrl
1790 1 adminx S 13212 1.4 0 0.0 pctime
1879 1 adminx S 13212 1.4 3 0.0 sched_daemon
1646 1 adminx S 13212 1.4 0 0.0 check_watchdog
1546 1 adminx S 13212 1.4 2 0.0 wpsaide
1788 1 adminx S 13212 1.4 1 0.0 bwdpi_check
1789 1 adminx S 13212 1.4 2 0.0 hour_monitor
1818 1 adminx S 13212 1.4 1 0.0 amas_ssd_cd
2343 1 adminx S 13212 1.4 3 0.0 disk_monitor
1785 1 adminx S 12832 1.3 2 0.0 /usr/sbin/lighttpd-monitor
1499 1 adminx S 12096 1.2 0 0.0 asd
1640 1 adminx S 11592 1.2 2 0.0 httpds -s -i br0 -p 8443
1641 1 adminx S 11120 1.1 2 0.0 httpd -i br0
3618 1 adminx S 10148 1.0 2 0.0 /usr/sbin/smbd -D -s /etc/smb.conf
3616 1 adminx S 9868 1.0 0 0.0 /usr/sbin/nmbd -D -s /etc/smb.conf
3620 3616 adminx S 9588 1.0 0 0.0 /usr/sbin/nmbd -D -s /etc/smb.conf
1545 1 adminx S 9532 1.0 0 0.0 wps_pbcd
1540 1 adminx S 8264 0.8 0 0.0 hostapd -B /tmp/wl0_hapd.conf
1543 1 adminx S 8156 0.8 0 0.0 hostapd -B /tmp/wl1_hapd.conf
2197 1 adminx S 8064 0.8 0 0.0 usbmuxd
1550 1 adminx S 7960 0.8 3 0.0 /usr/sbin/awsiot
1642 1 adminx S 7320 0.7 0 0.0 /usr/sbin/infosvr br0
1505 1 adminx S 7216 0.7 3 0.0 protect_srv
1704 1 adminx S 7164 0.7 1 0.0 /usr/lib/ipsec/starter --daemon ch aron
1569 1 adminx S 5540 0.5 0 0.0 /usr/sbin/wlceventd
1628 1 adminx S 5252 0.5 1 0.0 nt_actMail
1548 1 adminx S 5236 0.5 1 0.0 /usr/sbin/wlc_monitor
1547 1 adminx S 5208 0.5 3 0.0 /usr/sbin/wlc_nt
1891 1 adminx S 5152 0.5 2 0.0 fsmd
1649 1 adminx S 4532 0.4 1 0.0 rstats
1644 1 adminx S 4164 0.4 1 0.0 sysstate
2300 1 adminx S 4096 0.4 0 0.0 /usr/sbin/ntp -t -S /sbin/ntpd_syn ced -p pool.ntp.org -p time.nist.gov
1735 1 adminx S 3692 0.3 0 0.0 /usr/sbin/acsd2
5946 1888 adminx S 3660 0.3 2 0.0 dropbear -p 192.168.1.1:22 -j -k
1888 1 adminx S 3532 0.3 0 0.0 dropbear -p 192.168.1.1:22 -j -k
1672 1 adminx S 3496 0.3 1 0.0 lld2d br0
3438 1 adminx S 3444 0.3 3 0.0 miniupnpd -f /etc/upnp/config -1
1431 1 adminx S 3424 0.3 0 0.0 /sbin/syslogd -m 0 -S -O /tmp/sysl og.log -s 256 -l 6
1433 1 adminx S 3424 0.3 1 0.0 /sbin/klogd -c 5
3672 1 adminx S 3424 0.3 2 0.0 /sbin/udhcpc -i eth0 -p /var/run/u dhcpc0.pid -s /tmp/udhcpc_wan -A5 -O33 -O249
1615 1 adminx S 3424 0.3 3 0.0 crond -l 9
6000 5946 adminx S 3424 0.3 2 0.0 -sh
21407 6000 adminx R 3424 0.3 0 0.0 top -bn1
1839 1834 nobody S 3416 0.3 0 0.0 lldpd -L /usr/sbin/lldpcli -I eth4 ,eth3,eth2,eth1,eth5,eth6,eth7,wl0.1,wds0.*.*,wds1.*.* -s RT-AX86U
1834 1 adminx S 3416 0.3 2 0.0 lldpd -L /usr/sbin/lldpcli -I eth4 ,eth3,eth2,eth1,eth5,eth6,eth7,wl0.1,wds0.*.*,wds1.*.* -s RT-AX86U
1584 1 nobody S 3204 0.3 2 0.0 avahi-daemon: running [RT-AX86U-F1 D0.local]
1521 1 adminx S 3168 0.3 0 0.0 /bin/eapd
1559 1 adminx S 3160 0.3 1 0.0 /bin/ceventd
1561 1 adminx S 3136 0.3 1 0.0 /usr/sbin/debug_monitor /data
3601 1 nobody S 2648 0.2 3 0.0 dnsmasq --log-async
3602 3601 adminx S 2648 0.2 1 0.0 dnsmasq --log-async
1514 1 adminx S 2392 0.2 1 0.0 /usr/sbin/haveged -r 0 -w 1024 -d 32 -i 32
357 1 adminx S 2036 0.2 2 0.0 /usr/sbin/envrams
2321 1 adminx S 1952 0.2 2 0.0 /bin/mcpd
3619 1 adminx S 1876 0.2 1 0.0 /usr/sbin/wsdd2 -d -w -i br0 -b sk u:RT-AX86U,serial:3c7c3f6bf1d0
354 1 adminx S 1728 0.1 3 0.0 hotplug2 --persistent --no-coldplu g
1821 1 adminx S 1720 0.1 0 0.0 /usr/sbin/sd-idle-2.6 -i 60
350 1 adminx S 1584 0.1 0 0.0 {wdtctl} wdtd
684 2 adminx SW 0 0.0 0 0.0 [wl0-kthrd]
259 2 adminx SW 0 0.0 0 0.0 [bcmsw_rx]
457 2 adminx SWN 0 0.0 2 0.0 [jffs2_gcd_mtd9]
251 2 adminx SW 0 0.0 3 0.0 [fc_evt]
252 2 adminx SW 0 0.0 0 0.0 [fc_timer]
7 2 adminx SW 0 0.0 1 0.0 [rcu_preempt]
802 2 adminx SW 0 0.0 1 0.0 [dhd_watchdog_th]
260 2 adminx SW 0 0.0 0 0.0 [enet-kthrd]
687 2 adminx SW 0 0.0 0 0.0 [wfd0-thrd]
98 2 adminx SW 0 0.0 2 0.0 [kworker/2:1]
35 2 adminx SW 0 0.0 1 0.0 [skb_free_task]
3 2 adminx SW 0 0.0 0 0.0 [ksoftirqd/0]
693 2 adminx DW 0 0.0 3 0.0 [avs]
9588 2 adminx SW 0 0.0 0 0.0 [kworker/0:0]
1428 2 adminx SW 0 0.0 3 0.0 [kworker/3:2]
67 2 adminx SW 0 0.0 1 0.0 [kworker/1:1]
20109 2 adminx SW 0 0.0 0 0.0 [kworker/0:6]
19 2 adminx SW 0 0.0 2 0.0 [ksoftirqd/2]
14 2 adminx SW 0 0.0 1 0.0 [ksoftirqd/1]
17235 2 adminx SW 0 0.0 0 0.0 [kworker/0:3]
24 2 adminx SW 0 0.0 3 0.0 [ksoftirqd/3]
258 2 adminx SW 0 0.0 3 0.0 [sw0HouseKeeping]
253 2 adminx SW 0 0.0 3 0.0 [bcmFlwStatsTask]
13 2 adminx SW 0 0.0 1 0.0 [migration/1]
23 2 adminx SW 0 0.0 3 0.0 [migration/3]
6 2 adminx SW 0 0.0 0 0.0 [kworker/u8:0]
10 2 adminx SW 0 0.0 0 0.0 [migration/0]
18 2 adminx SW 0 0.0 2 0.0 [migration/2]
161 2 adminx SW 0 0.0 3 0.0 [ubi_bgt1d]
11 2 adminx SW 0 0.0 0 0.0 [watchdog/0]
12 2 adminx SW 0 0.0 1 0.0 [watchdog/1]
17 2 adminx SW 0 0.0 2 0.0 [watchdog/2]
22 2 adminx SW 0 0.0 3 0.0 [watchdog/3]
2 0 adminx SW 0 0.0 0 0.0 [kthreadd]
5 2 adminx SW< 0 0.0 0 0.0 [kworker/0:0H]
8 2 adminx SW 0 0.0 2 0.0 [rcu_sched]
9 2 adminx SW 0 0.0 0 0.0 [rcu_bh]
16 2 adminx SW< 0 0.0 1 0.0 [kworker/1:0H]
21 2 adminx SW< 0 0.0 2 0.0 [kworker/2:0H]
26 2 adminx SW< 0 0.0 3 0.0 [kworker/3:0H]
27 2 adminx SW< 0 0.0 1 0.0 [khelper]
28 2 adminx SW 0 0.0 1 0.0 [kdevtmpfs]
29 2 adminx SW< 0 0.0 1 0.0 [writeback]
31 2 adminx SWN 0 0.0 1 0.0 [ksmd]
32 2 adminx SW< 0 0.0 1 0.0 [crypto]
33 2 adminx SW< 0 0.0 1 0.0 [bioset]
34 2 adminx SW< 0 0.0 1 0.0 [kblockd]
36 2 adminx SWN 0 0.0 1 0.0 [kswapd0]
37 2 adminx SW 0 0.0 1 0.0 [fsnotify_mark]
62 2 adminx SW 0 0.0 2 0.0 [btnhandler0]
63 2 adminx SW 0 0.0 2 0.0 [btnhandler1]
64 2 adminx SW 0 0.0 2 0.0 [btnhandler2]
65 2 adminx SW 0 0.0 1 0.0 [bpm_monitor]
66 2 adminx SW< 0 0.0 2 0.0 [linkwatch]
68 2 adminx SW< 0 0.0 2 0.0 [ipv6_addrconf]
69 2 adminx SW< 0 0.0 1 0.0 [deferwq]
70 2 adminx SW 0 0.0 2 0.0 [ubi_bgt0d]
170 2 adminx SW 0 0.0 3 0.0 [ubifs_bgt1_0]
270 2 adminx SW 0 0.0 3 0.0 [pdc_rx]
565 2 adminx SW< 0 0.0 0 0.0 [cfg80211]
803 2 adminx SW 0 0.0 3 0.0 [wfd1-thrd]
1332 2 adminx SW 0 0.0 0 0.0 [kworker/u8:3]
11637 2 adminx SW 0 0.0 2 0.0 [kworker/2:2]
17629 2 adminx SW 0 0.0 1 0.0 [kworker/1:0]
21389 2 adminx SW 0 0.0 0 0.0 [kworker/0:1]
29463 2 adminx SW 0 0.0 3 0.0 [kworker/3:1]
Hello,
I have observed something similar with the RT-AX86U Pro. I'm running the Stock ASUS Firmware (3.0.0.6.102_34336 -- latest version as of 3 March 2025) and I'm getting a steady increase in dropped packets on br0 (my LAN bridge). About 3 dropped packets per second. This is what "ifconfig" showed after the router was up for about 1 week.
br0 Link encap:Ethernet HWaddr 08:BF:B8:45:97:88
inet addr:192.168.15.2 Bcast:192.168.15.255 Mask:255.255.255.0
RX packets:33923885 errors:0 dropped:1722223 overruns:0 frame:0
TX packets:33826646 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:9224067796 (8.5 GiB) TX bytes:24447799483 (22.7 GiB)
I promise there is nothing wrong with the cables.
None of the members of the LAN bridge showed any dropped packets at all, except for eth5 -- which only showed 9276 dropped packets over the same period of time (about 1 dropped packet every 70 seconds or so)
FWIW, I have also posted in this forum that I see a 50-60% drop in VPN speed when I use this router versus a much older RT-AC68U (really old). The VPN runs on an external server and connects to a VPN on the other side of the Atlantic Ocean that is also getting routed through an older ASUS RT-AC86U. Neither of those other ASUS routers show any significant dropped packets over long periods of time. I reported the problem to ASUS and they completely ignored me. I also reported this problem here in snbforumns and nobody replied.
I'm increasingly convinced the ASUS RT-AX86U (and PRO) are pieces of crap, and ASUS just doesn't want to admit it.
Similar to my experience, I ceased using it in November and switched to Omada. About four days ago, I decided to reset everything on the AX86U, and it has been stable ever since—no Wi-Fi or PPPoE drops. My PPPoE drops initially lasted from a few seconds to a minute. I found that changing the internet detection method from PPP ECHO to DNS PROBE temporarily resolved the issue, but over time, it would fail completely, preventing the connection from automatically restoring. Despite trying all possible solutions, I was unable to resolve the problem. Asus suggested sending the router in for "repairs," but the cost was pretty high. Lets see how much time it last this round. Or until im able to cover the home with at least two omada APs, the router from omada doesn't have the same range as the asus.
Hello,
In my experience, dropped packets could cause by so many factors from hardware, software by so many devices involved along the interlinked! I've been using RT-AX86U since 2021 and it's pretty reliable. It seems the Pro version of AX86U having the problems since released... why didn't you try the AX86U? Good luck! (Maybe your ISP could be an issue too... is your Internet fiber or copper? if Fiber, you could ask the ISP to fetch the port on their end or maybe clean up the fiber connector where your line is ended , usually a switch!)
