AC56U With Non Bridge-able Modem
davidml
Hi
I had since now a modem - dlink 320 b - connected in bridge mode to Asus RT-AC56U.
Worked very fine.
But now , i will migrate soon on VDSL and i need to use again Livebox (orange Modem-router ) with no Bridge mode.
to prepare this , i reinstalled a very old Livebox (modele 2 - the VDSL one is LB3) to test the connection.
I'm trying to setup Asus router but with no success.
my network : (adsl) <-> LiveBox Modem router <-> Asus RT-AC56U <-> Switch <-> PCs
As the LB has not Bridge modem capabilities :
i tried this :
LiveBox Modem : configured to do PPPoe connection with user id and password.
Lan 192.168.2.1 for Livebox
Livebox connected to Wan port of Asus (from Livebox ethernet red output ).
Asus :
Lan : 192.168.1.1 , DHCP ON. all my pcs can access to all others,
but I can not connect to internet.
I know , as not bridged modem, i can not use the PPPoe connection from router.
What can i do for accessing internet : i tried Automatic ip, Static IP , but nothing Works.
In Static IP : i tried this :
WAn ip address : 192.168.2.10 (Asus is IN DMZ on LIvebox side , fixed IP 192.168.2.1 based on Asus Mac Address)
255.255.255.0
default Gateway 192.168.2.1
I have this kind of message in System logs :
Jan 1 03:37:57 kernel: br0: port 1(vlan1) entering forwarding state
Jan 1 03:37:57 miniupnpd[2484]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Jan 1 03:37:57 miniupnpd[2484]: Failed to get IP for interface eth0
Jan 1 03:37:57 miniupnpd[2484]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Jan 1 03:37:57 kernel: device eth0 left promiscuous mode
Jan 1 03:37:57 kernel: device eth0 entered promiscuous mode
Jan 1 03:37:57 kernel: br0: topology change detected, propagating
Have you an idea ?
Solved
Hi, finally solved this :
i have done a reset factory , and used the wizard to connect , it worked fine , switched to automatic Ip mode and connection was OK....:(
For those who wants to connect Livebox :
connect to livebox :
change IP lan to 192.168.2.1 ,
you can still use dhcp , add a rule to connect Asus to 192.168.2.10 (by this Mac Address),
Add Asus - 192.168.2.10 in DMZ.
connect Red Port of livebox to Asus Wan Port
And Run Wizard to connect.
Initially , Asus was defined in 192.168.1.2 , not sure this was the reason nothing worked.
V RT-AC66U B1 Media Bridge DHCP bug remains ASUS AC Routers & Adapters (Wi-Fi 5) 11
