Diversion AC66-U 192.168.120.4/ca.crt produces a blank screen and no ca.crt for any devices
Make WiFi Great Again
I have an AC66-U running latest AMTM latest Diversion and latest Beta Johns fork on an old but perfectly working AC66-U. Diversion standard installs normally with no errors. but when its time to go to 192.168.120.4/ca.crt in the ol web browser nothing comes up but a blank screen. the routers ip is 192.168.120.5 the dhcp range is 192.168.120.6-192.168.120.35 and pixelserv is set to 192.168.120.4 so what gives?
Use a different browser? Try incognito or InPrivate mode?
Have you tried re-installing Diversion?
Did you do a dirty upgrade to the latest Beta? From which firmware version? A full reset may be required.
I have tried 5 different broweser on 2 different laptops and 4 lablets as well. Im on the latest version at this time, 46D7 though i tried a few earlier versions as well. I didreset the router and even cleared the nvram to no avail. I noticed that ca.crt is actually in the usb stick under /opt/var/something else i cant remember the exact directory but i did find it there and was able to manually import it into clients so that shows it is correctly made and configured but it wont show up under the 192.168.120.4/ca.crt method of access.
I did try a dirty upgrade but i alao tried clean installing nothing has made it work correctly. Uninstalled and reinstalled amd even formatted usb stick many times each by now
Hi All,
I have the same set-up and had same issue, I believe this is because the entware repo for our old ac66u is not updated anymore. You need to:
- install the "entware-backport" repo (under diversion -> option "ep" -> then option 6 "manage entware packages" -> then again option 6 "Parallel use Entware-backports Repo")
- opkg update
- opkg upgrade
Hi All,
- opkg update
- opkg upgrade
That's the correct way for @Make WiFi Great Again to solve his issue. The older pixelserv-tls version in the no longer maintained MIPSEL Entware repository does not support the <pixelserv-tls IP>/ca.crt command. However, the also no longer maintained maurerr.github.io repo with pixelserv-tls v2.2.1 does.
I have spent hours on this in my spare time while here on vacation at my fathers house and knew there was something i was not understanding going on! Ac66u may be old and decrepit but its plenty good enough for this old farmhouse and its 30mbps\2mbps connection to the world thanks everyone.
now i just wish that firewall script skynet would install but it said not supported because my ipset is too old. i guess it dont work on such old things. no worries there. as well thats ok diversion was the priority here.
