kevindd992002
I use my AC66U in AP mode as my main firewall/router is pfsense. I just got my new Nvidia Shield TV Pro 2019 and connected it to my AP's 5GHz Guest network (as my main 5GHz network is using a Radius server for authentication and the Shield does not support that). Everything seemed to be fine last night. When I woke up this morning, the AP is rebooting every 15-20 minutes or so. I've disconnected my Shield temporarily and the problem went away.
What could be causing this? I have IPv6 disabled on my Shield if that matters. Which logs in the AP can I check to pinpoint the root cause? I'm using Merlin's v380.70 firwmare (latest). Can HW Acceleration have any effect on this? And where do you exactly disable HW Acceleration? I don't see a section anywhere to disable that explicitly.
@RMerlin , do you have any ideas?
