AC66U Website not reachable
Warhawk911
Hi Guys,
AC66U Firmware Version:3.0.0.4.382_52287
So one of the thumbnailing server for a Newsgroup service is not reachable, I tested access from my PC directly on Cable Modem and on my cell phone LTE and its loading. Also working on the router when i use a VPN connection. But when I am directly connected to the router or by wifi, the site does not load.
The website is th.easynews.com , without credential it should return a 403 Forbidden, and this is ok. But when connected to the router, it returns This site can’t be reached ( ERR_CONNECTION_ABORTED ).
When I telnet to the router and run "wget" I get the good status
Connecting to th.easynews.com|69.16.190.82|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2020-09-10 15:04:41 ERROR 403: Forbidden.
But when i used a connected device to the router i get:
--2020-09-10 15:06:55-- (try: 7) http://th.easynews.com/
Connecting to th.easynews.com (th.easynews.com)|69.16.190.82|:80... connected.
HTTP request sent, awaiting response... No data received.
I decided to Factory reset the router and it is still not working.
I notice that after the reset, my ports forwarding are not showing in the Asus WebConfiguration as expected but they are still in the iptable firewall... ?
Do you guys have any clues or any files I should check for ghost config?
Thank you
admin@RT-AC66U:/tmp/home/root# iptables --list
Chain INPUT (policy ACCEPT)
target prot opt source destination
DROP icmp -- anywhere anywhere icmp echo-request
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
DROP all -- anywhere anywhere state INVALID
PTCSRVWAN all -- anywhere anywhere
PTCSRVLAN all -- anywhere anywhere
ACCEPT all -- anywhere anywhere state NEW
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
INPUT_ICMP icmp -- anywhere anywhere
Chain FORWARD (policy ACCEPT)
ACCEPT all -- anywhere anywhere ctstate DNAT
Chain OUTPUT (policy ACCEPT)
OUTPUT_DNS udp -- anywhere anywhere udp dpt:domain u32 0x0>>0x16&0x3c@0x8>>0xf&0x1=0x0
OUTPUT_DNS tcp -- anywhere anywhere tcp dpt:domain u32 0x0>>0x16&0x3c@0xc>>0x1a&0x3c@0x8>>0xf&0x1=0x0
OUTPUT_IP all -- anywhere anywhere
Chain ACCESS_RESTRICTION (0 references)
Chain FUPNP (0 references)
ACCEPT udp -- anywhere 192.168.1.212 udp dpt:47999
ACCEPT udp -- anywhere 192.168.1.212 udp dpt:48010
ACCEPT udp -- anywhere 192.168.1.212 udp dpt:47998
ACCEPT udp -- anywhere 192.168.1.212 udp dpt:48000
ACCEPT udp -- anywhere 192.168.1.212 udp dpt:48002
ACCEPT tcp -- anywhere 192.168.1.2 tcp dpt:32400
Chain INPUT_ICMP (1 references)
RETURN icmp -- anywhere anywhere icmp echo-request
RETURN icmp -- anywhere anywhere icmp timestamp-request
ACCEPT icmp -- anywhere anywhere
Chain OUTPUT_DNS (2 references)
logdrop_dns all -- anywhere anywhere STRING match "|10706f697579747975696f706b6a666e6603636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|0d72666a656a6e666a6e65666a6503636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|1131306166646d617361787373736171726b03636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|0f376d667364666173646d6b676d726b03636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|0d386d617361787373736171726b03636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|0f3966646d617361787373736171726b03636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|1265666274686d6f6975796b6d6b6a6b6a677403636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|086861636b7563647403636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|076c696e77756469056633333232036e657400|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|0f6c6b6a68676664736174727975696f03636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|0b6d6e627663787a7a7a313203636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|077131313133333303746f7000|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|057371353230056633333232036e657400|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|077563746b6f6e6503636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|0e7a786376626d6e6e666a6a66777103636f6d00|" ALGO name bm TO 65535 ICASE
logdrop_dns all -- anywhere anywhere STRING match "|0a65756d6d6167766e627003636f6d00|" ALGO name bm TO 65535 ICASE
Chain OUTPUT_IP (1 references)
logdrop_ip all -- anywhere 193.201.224.0/24
Chain PControls (0 references)
Chain PTCSRVLAN (1 references)
Chain PTCSRVWAN (1 references)
Chain SECURITY (0 references)
RETURN tcp -- anywhere anywhere tcp flags:FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
DROP tcp -- anywhere anywhere tcp flags:FIN,SYN,RST,ACK/SYN
RETURN tcp -- anywhere anywhere tcp flags:FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
DROP tcp -- anywhere anywhere tcp flags:FIN,SYN,RST,ACK/RST
RETURN icmp -- anywhere anywhere icmp echo-request limit: avg 1/sec burst 5
RETURN all -- anywhere anywhere
Chain default_block (0 references)
Chain logaccept (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix `ACCEPT '
Chain logdrop (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix `DROP '
Chain logdrop_dns (16 references)
LOG all -- anywhere anywhere LOG level warning tcp-sequence tcp-options ip-options prefix `DROP_DNS '
Chain logdrop_ip (1 references)
LOG all -- anywhere anywhere LOG level warning tcp-sequence tcp-options ip-options prefix `DROP_IP '
