AC66U - Why not more throughtput of 150Mbps?
citytrader
Hello to all, I will like to know why I'm not getting more than 150Mps of throughput of my router AC66U at 5Ghz, is this something normal?
I tested that speed with iperf between my computer connected by cable to the router and my phone LG G2.
The connection in my phone says 433Mhz and is next to the router.
My firmware is Merlin: 374.43
Thanks!
The phone is the weak point. Try an AC equipped laptop instead.
Try different channels and or try switching the antenna leads.
I tried all channels yet without look, and for the antenna I think it wont change anything because in the test I put the laptop near the router...
Could be some fault in my router?...
What's easier to try? Buy and setup a new router or switch leads?
On the other hand, it could be your 7260 card too.
Do you have another laptop to try with?
I remember one user had wireless issues specifically because he had switched the two antennas while upgrading his laptop. I would still give this a try, just in case.
Unfortunately I dont have a laptop with 5Ghz... probably is the crap wifi of this laptop, even if it cost a lot... damn HP.
At least I'm having fastethernet speed...
The wifi card is connected correctly because the antenna has the numbers that match the card.
