Ac68u crashes when aimesh and you modify the guest Network
Eric Lieb
Since the latest fw update my ac68u will brick itself if I try to disable or edit a guest network after I turn one on. I have to do a recovery boot to get it to even go to a setup page.
nothing new, SSH to the router should help and enter: service restart_httpd
Router works in background only GUI faulty.
ok, thats really different!
First step will be factory reset and initialize hoping this will resolve it.
Have you done a factory reset on your router? What firmware version are you running?
Firmware: 3.0.0.4.384_45149
I have just finished factory resetting and setting up two AiMesh Nodes which connect to the AiMesh Router.
I just finished experimenting with some things and the results are odd.
Here are my experiments and results:
Via Desktop 192.168.1.1: Enabled 2.4 GHz Guest Network
Result: Router Crash/Reboot
Via Asus Router Android App: Enabled 5 GHz Guest Network
Result: Success
Via Asus Router Android App: Enabled 2.4 GHz Guest Network
Result: Success
Via Asus Router Android App: Modified Existing 5 GHz Guest Network Timer
Result: Success
Via Asus Router Android App: Modified Existing 2.4 GHz Guest Network Password
Result Router Crash/Reboot
So it seems to be hit or miss...I'm not sure if there's a way to pin point what will cause it to succeed or fail.
