AC68U portforward with UTORRENT Out Of Order
chungsm
I already set the portforward in AC68U and Utorrent.
But cameout , Utorrent the connectting port was different with the Utorrent connecting port.
For Example : AC68U set PORT to 62000 , Also Utorrent set to same port number . After confirm the setting , open the running Utorrent interface , the PORT number show 142 , NOT 62000.
Please advise how to slove this problem.
Many Thanks
Upnp in the router takes care of port forwarding with out any issues most of the time. Thus you don't need to manually set port in the router.
In utorrent, manually assign a port of 45xxx, example; 45650. Close and restart utorrent for manually assigned port to take in to affect using routers upnp.
You would be more secure to let µTorrent open and close port using UPnP rather than port forward which leaves port open all the time.
Enable it in preferences > connection > Enable UPnP port mapping
This morning when I poweron the computer , the UTORRENT port number , change back to 3 figure again .
So SAD
