[AC86U] Can VPN server config be deleted?
Patrick9876
I'm about to try creating a VPN (OpenVPN) server on my AC86U and expect needing to try a number of configurations before I get what I want. Is there a way to delete an instance of a VPN server without doing a factory reset? (The answer may be obvious once I've gone through the process, but I'd like to know before I start.) I notice that 2 instances are supported (at least under Merlin 384.14.2) but I expect I'll need more than 2 attempts.
If the instance cannot be deleted, can the configuration be changed an a new client definition be exported? If the answer is "Yes", are there options that cannot be changed?
The client is going to live on a laptop running Windows with internet connectivity provided by a tethered cell phone on an AT&T network. Windows, AT&T, and my ignorance may dictate changing my initial attempts at configuring the server.
Things that I may need to change:
  • Client VPN access (If Windows lets me use the VPN client to access my LAN and an Ethernet port to access everything else, I want "LAN only", but I suspect I will have to use the VPN for internet access.)
  • OpenVPN port (although I don't think AT&T blocks this)
  • VPN subnet (My ignorance. Is my LAN's subnet NATed to this?)
OK. I've answered one of my questions. The default port it fine - not blocked.
And I sort of answered another: I don't think I need to give the VPN server internet access. My laptop was perfectly happy to continue using its Ethernet connection. In fact, I could not figure out how to get it to use the VPN connection. I was able to get a perfectly good VPN client-to-server connection but have no idea how to tell Windows to use it. I obviously need to find some Windows oriented OpenVPN doc. (There are many tutorials on how to install OpenVPN on Windows, how to run it, and how to make connections. I can find nothing on how to use it.)
I'm going to abandon this thread because the original question is irrelevant. As near as I can tell, I can change server options on the fly without deleting and rebuilding the instance of the VPN server. New problems will be mentioned in a new thread.
