Jesper Rank Rasmussen
Hello.
I have been searching for solution to my AC87U Port forward and WIFI issues.
Got a colleague showing to the merlin custem firmware, and the newest beta build have for the moment solved my WIFI problem. However, portforward are still not working.
Is there something I can do?
I have tried,
Hope someone have a thing i haven't tried yet
Best regards
Jesper
I have tried,
- Factory reset
- Disable NAT Acceleration
- Using UPNP only (Turn it on and off)
- UPNP disabled and manuel port forward as displayed below (Fun part, is it shows as working, however nothing gets to the other side)
- Using my old RT56U (Working fine) as a main router and the AC87U as a relay (Working), even got better connecting with this setup then with the RT56U only.
- Normal Firmware (First build), Newest build, Merlin, DD-WRT (Crashed and had to use the restore tool)
- Change or disable the NAT Loopback
Best regards
Jesper
