Actiontec ECB6200 loss / filtering?
jea101
What is the insertion loss between coax in and TV/STB out?
Doe it block (filter) MOCA on the TV/STB out port?
I don’t know the specific attenuation value but MoCA devices shouldn’t be connected off that port (TV/STB Out).
From the user manual:
LAN Connections
Coax In Frequency Range - Extended D-band: 1125MHz ~ 1675MHz;
 Full Port Range: 5MHz ~ 2150MHz
TV/STB Out Frequency Range - 5MHz ~ 1002MHz
I believe a diplexer is used, effectively, so the attenuation is likely 40+ dB.
It appears that I wasn’t clear in what I was asking.
I want to know the signal reduction/loss (if any) for TV and cable modem signals that pass through the 6200.
Separately I want to know if the 6200 prevents MOCA from appearing at the TV out port which may cause interference with my Cisco STA1520 tuning adapters. The TV/STB out 5 to 1002 MHz range does imply that it is filtered.
I haven't seen any specs that detail the ECB6200 losses (may require emailing Actiontec), but going with typical diplexer specs, you should expect:
~1 dB loss for pass-band frequencies
40+ dB loss for stop-band frequencies
For the TV/STB Out port:
* pass-band = 5-1002 MHz
* stop-band = frequencies above 1002 MHz​
So a cable signal would see approx. 1 dB loss between the ECB6200 adapter's Coax In port and its TV/STB Out port, while MoCA signals would be hit with 40+ dB attenuation.
As for your SDV Tuning Adapter, it would ideally be connected via the TV/STB Out port of the ECB6200, owing to (1) the minimal loss for cable frequencies passing between the Coax In and TV/STB ports, and that (2) connecting the TA via this port would protect it from MoCA signals, which can be problematic for some TA models.
