Adblockin/ipfilter help implemation
I am a terrible bash script/programmer can someone please help?
Then I would move on and look elsewhere for a script that does what your linked files do.
Both will not work without heavily modifying it. And even then, they are not intended for a router with limited resources.
Both of these scripts more or less duplicate the functionality of both Skynet and AB-Solution (in a much more primitive way). The first just downloads some outdated (and stolen) lists from iBlockList. The second sources a bunch of Ad/Tracking domains. I'm sure if you did the analytics you would see 99% of the content from these scripts is already blocked from both Skynet and AB respectively.
Hi I am trying to get the following currently I have Skynet, absolution, dnscrypt however I want to also take advantage of the following I am a terrible bash script/programmer can someone please help?
https://gist.githubusercontent.com/...e45f8c8ffc06b1156f7915f0cfcff48/blockpeers.sh
and
https://github.com/notracking/hosts-blocklists
I don't 100% understand what you're trying to do here. If that script is intended for p2p block, it could be ok (with some adjustments) but if you want to block ads/trackers that's not the way. IMHO if you're not confident in scripting, both guys above, offers more than enought protection for average user needs.
