Adding OpenVPN Client to DNS
TechnoSwiss
I've been searching and trying to get this working and I'm coming up blank, most of the posts I'm finding are about pushing DNS to the OpenVPN clients (that's working great) or adding hosts to the configuration file (that's also working great). What I want to do however is when my OpenVPN client connects to the router, I want the DNS updated with that clients OpenVPN address, so that other hosts on the network can resolve the client to an IP address. I've got a script running on client connect, I've tried 'dnsmasq --host-record=$common_name,$ifconfig_pool_remote_ip' but all that manages to do is create another instance of dnsmasq, not actually add the host-record into the running instance. I also tried using the addhosts option in dnsmasq config since it looks like it's supposed to read in new hosts files as they're added to the directory, but I just get an error that the option isn't supported. Is there a way to setup OpenVPN to add it's clients to dnsmasq just like the dhcp-clients on the local network (or setup the dhcp server in OpenVPN to do it?) or, is there a way to add new hosts to the running instance of dnsmasq from the script? Thanks.
The correct directive which defines additional hosts is ...
addn-hosts=/jffs/addn-hosts
If you add that directive to the DNSMasq configuration, then update the associated file w/ the appropriate address or host-record directive (preferred) for each OpenVPN client as they connect, you can send the following signal to the running dnsmasq instance to force it to reread that file and thus DNS resolution will work.
killall -HUP dnsmasq
Thanks, that's what I ended up doing, addn-hosts=/jffs/hosts.openvpn
Then in my script that runs on OpenVPN client I did:
#!/bin/sh
matches_in_hosts="$(grep -n "$ifconfig_pool_remote_ip\|$common_name" /jffs/hosts.openvpn | cut -f1 -d: | sort -r)"
host_entry="$ifconfig_pool_remote_ip $common_name"
if [ ! -z "$matches_in_hosts" ]
then
    # iterate over the line numbers on which matches were found
    for line_number in ${matches_in_hosts}
    do
       printf "%d\n" "$line_number"
        # delete each line where match was found
        sed -i -e "${line_number}d" /jffs/hosts.openvpn
    done
fi
echo "$host_entry" | tee -a /jffs/hosts.openvpn > /dev/null
kill -HUP $(pidof dnsmasq)
