dnsmasq.conf.add not working on Guest Network Pro clients
Based on what I learned here, I am hoping someone could please review this script and let me know if they think this is a proper way to get the bridge and subnet info for a dsnmasq-sdn.postconf script:
Bash:
#!/bin/sh
CONFIG=$1
SDN=$2
source /usr/sbin/helper.sh
#Determine bridge name and subnet info of this SDN
sdn_rl=$(nvram get sdn_rl)
subnet_rl=$(nvram get subnet_rl)
#From mtlan_utils.c:
#sdn_rl
 # sdn_idx, sdn_name, sdn_enable, vlan_idx, subnet_idx,
 # apg_idx, vpnc_idx, vpns_idx, dnsf_idx,
 # urlf_idx, nwf_idx, cp_idx, gre_idx, fw_idx,
 # killsw_sw, ahs_sw, wan_idx, ppprelay_sw, wan6_idx,
 # createby, mtwan_idx, mswan_idx, prio
#subnet_rl
 # idx, ifname, addr, netmask, dhcp_enable, dhcp_min, dhcp_max,
 # dhcp_lease, domain_name, dns, wins, dhcp_res, dhcp_res_idx,
 # v6_enable, v6_autoconf, addr6, dhcp6_min, dhcp6_max, dns6,
 # dot_enable, dot_tls
#get subnet_idx
SDNidx=$(echo $sdn_rl | tr '<' '\n' | awk -F'>' '{print $1 ":" $5}' | grep "^"$SDN":" | awk -F':' '{print $2}')
#get ifname, addr, netmask
SUBNETrow=$(echo $subnet_rl | tr '<' '\n' | awk -F'>' '{print $1 ":" $2 " " $3 " " $4}' | grep "^"$SDNidx":" | awk -F':' '{print $2}')
BR=$(echo $SUBNETrow | awk '{print $1}')
IPBASE=$(echo $SUBNETrow | awk '{print $2}')
IPMASK=$(echo $SUBNETrow | awk '{print $3}')
#make config changes here:
if [ -n "$BR" ]; then
       logger -t "dnsmasq-sdn.postconf" "Updated dnsmasq-"$SDN "configuration with bridge" $BR "on subnet "$IPBASE"/"$IPMASK
else
       logger -t "dnsmasq-sdn.postconf" "Error: Subnet info for SDN" $SDN "not found"
fi
Thank you!
EDIT: Fixed error based on information found in Merlin source code (names of parameters in the NVRAM values)
I’m not in a position to make any comment on whether the code is correctly written or offer improvements but I would like to check something and ask if you would consider an option in it, if I may?
Does it just provide details (only) of the sdn and br parameters, the former for the naming of the multiple dnsmasq-sdn.conf.add files in /jffs/config/ and the latter for (e.g.) any iptables entries in firewall-start, or does it actually go on to create (at least) the dnsmasq files i.e. hat does the section “# make config changes here:” do? Also, can I ask why you chose to log to dnsmasq-sdn.postconf and not dnsmasq-sdn.conf.add?
If yes, it actually creates the files (to populate manually with manual assignments later), would it be possible to have it ask the question whether you want to do that first, so you can say no and it does not then overwrite any existing files you may have manually created or were created by YazDHCP? If I’ve misread what it might be doing, then put it down to lack of understanding and curiosity!
I have had use cases that needed the bridge/subnet information during dnsmasq configuration (e.g. creating and assigning an ULA to the virtual bridge and adding that to the configuration file). During configuration, one only gets the SDN index and would need to use that to get everything else. In general, I am hoping the experts can tell me if this is the wrong path or at least provide advice on how to find out more info.
Btw, the Wiki for custom Merlin configs (Link) states "dnsmasq-sdn.postconf (the SDN index number is passed as second argument, 1 is the first instance)". Does the info in this thread mean this statement should be updated?
I recently created a function that parses the get_mtlan output and makes it easy to query SDN entries and their related information, including the SDN name, bridge name, SDN index, and IPv6 status (enabled/disabled). The forum doesn't allow me to post the code here for some reason, so here's a link to my repo:
The function can output either pipe-separated (default) or human-readable formats. It also makes it easy to extract any field you need using awk. You can invoke it without arguments to list all SDNs, or pass an SDN index or bridge name to retrieve specific SDN properties.
Usage examples:
kuchkovsky@rt:/tmp/home/root# list_sdn  # default pipe-separated output
Guest|br54|3|0
IoT|br56|5|0
kuchkovsky@rt:/tmp/home/root# list_sdn -h  # human-readable output
name=Guest br=br54 sdn_idx=3
name=IoT br=br56 sdn_idx=5
kuchkovsky@rt:/tmp/home/root# list_sdn 3  # find SDN by index
Guest|br54|3|0
kuchkovsky@rt:/tmp/home/root# list_sdn 3 | awk -F '|' '{ print $2 }'  # extract the bridge name
br54
kuchkovsky@rt:/tmp/home/root# list_sdn br56  # find SDN by bridge name
IoT|br56|5|0
kuchkovsky@rt:/tmp/home/root# list_sdn br56 | awk -F '|' '{ print $3 }'  # extract the SDN index
5
I had a wee look around your GitHub page, impressive collection, quite some work (most of it well beyond me), but well done!
Keeping on topic, if someone wanted to use your particular script can you do so in isolation i.e. just save the one script to /jffs/scripts/ and run it …. or per your main page, do you still need to clone your repository, make backups (always a good idea) and allow the various existing scripts to be amended (nervous about doing this and probably will not attempt it for the one script, at least not right now).
No problem if not able to run in isolation, but then for this purpose I’d still really like to see @rung’s script developed to completion.
That's only if you need the functionality of a specific add-on (basically, a set of related scripts) listed in README. I'll probably create proper installers for them later.
Regarding the specific list_sdn function, it can be copied and used directly, as it doesn't have any dependencies. It's part of an add-on, but it can be used separately. You can even paste it directly into SSH and then invoke it.
That’s great, thank you for the clear explanation, much appreciated.
[EDIT]. Works a treat!
Nice job on the scripts! Btw, not sure there is any advantage one way or the other, but here is what I use to list the bridges:
Bash:
brctl show | awk 'NF>1 && NR>1 {print $1}'
Rung
I wonder how @Martinski determines this in YazDHCP… :)
The *active* list has it at "4", but the persistent list has it at "6". I'm sure YazDHCP knows to use the SDN Feature Index to get this.
Like many users on these forums, I also spent a few hours trying to figure out and understand as much as possible the general framework of the Guest Network configurations as implemented in the 3006.102.x F/W when running multiple instances of dnsmasq.
As part of that preliminary phase, I wrote some simple shell scripts that parse various NVRAM variables to gather all the relevant information WRT Guest Networks so I could eventually implement the new feature for YazDHCP. I also wrote a routine to parse the output of the 'get_mtlan' command (along with other NVRAM variables) and to display the relevant info in a more user-friendly format. I then ran those scripts on as many ASUS routers as I had available from friends, relatives, and a couple of co-workers so that I could see the pattern of information emerge.
Those script runs provided quite a lot of good, useful information that I could correlate with other info I had already gathered, but of all the info that was collected, the output from 'get_mtlan' provided a more complete data set, IMO.
Here's an example of the output from one shell script run:
At the end, however, since YazDHCP has to create/modify the correct '/jffs/configs/dnsmasq-{IDX}.conf.add' file that corresponds to each Guest Network configuration, I decided to go at it in a different way and get the dnsmasq file index directly from the '/etc/dnsmasq-{IDX}.conf' filename itself (before creating/modifying the associated files) by matching the virtual interface IDs and IP addresses used in the dnsmasq directives within the file. IMO, this was the quickest & safest way to make sure YazDHCP always gets the correct dnsmasq file index that corresponds to the virtual bridge interface ID assigned to each Guest Network configuration.
Just FYI.
A suite of informational scripts should be what Asus themselves distribute. Do you distribute your scripts anywhere? Show_Guest_Network_Info.sh, for example, looks exceptionally cool, and is the *exact* type of utility that would help a non-GUI user like me. Simply awesome! :)
Exactly what I did (at the advice of @dave14305). <3
I have now stored the custom shell script on my personal GitHub repo.
You can use the following commands to download it:
Bash:
curl  -LSs --retry 3 --retry-delay 5 --retry-connrefused \
https://raw.githubusercontent.com/Martinski4GitHub/CustomMiscUtils/master/Misc/Show_GuestNetwork_Info.sh \
-o "$HOME/Show_GuestNetwork_Info.sh" && chmod a+x "$HOME/Show_GuestNetwork_Info.sh"
Once downloaded into the router's HOME directory, you can, of course, move it to whatever location you prefer; it has no dependencies other than running on 3006.102.X F/W builds, and it requires no parameters. You're welcome to use/modify it as you see fit for your own purposes.
Sounds good. That way is like getting the info directly "from the horse's mouth" (so to speak ;):))...
@Martinski thank you very much for clarifying this, much appreciated.
Bash:
This is excellent. Great resource for SDN field definitions. Also will be helpful to debug any changes in future firmware versions.
Thank you!
Now that is how I roll! :D Fantastic script! While I appreciate the end-user ability of amtm, I don't see me using any utilities at this point. Scripts like *this* are not only useful, but educational. Well formatted, easily readable, and imminently functional. Thanks @Martinski! <3
EDIT: The utility I ran from the curl doesn't seem to have color like it did in the screenshot you posted. Idle curiousity if changed, or if there are additional settings you have enabled in a profile file that makes it so. I like to learn. :)
The shell script was not modified at all. The colors shown in my previous screenshot were a result of running the script on a MobaXterm SSH client terminal window. MobaXterm is one of my favorite SSH client applications, which I use most often. It's a great piece of software, highly customizable, and I especially like having multiple tabbed SSH client sessions running simultaneously.
I still use the PuTTY SSH client on occasion (e.g. when I need to use only one SSH terminal window to check or run something quickly), but for serious shell script development work, testing, and troubleshooting on the router, MobaXterm is king!! ;):)
As another example, here's a screenshot showing colors being automatically applied by the MobaXterm SSH client terminal to the output extracted from NVRAM variables:
I use RealVNC since it was the original tool built into my first Raspberry Pi. Never even considered any other tools over the years. I used Xterm at UC Berkeley in the '80s, so will check this out to see if it is similar. Thanks again for the knowledge! :D <3
