Adguard - GT-BE98PRO
cc666
I have 2 loT vlan's, 1 guest vlan. All working perfectly
I set up aAdguard in the Parental Controls, also logged in.
I then switched on Adguard on all the Vlans and logged in
When I go back to the settings in all Vlans and the Parental Contol area it is asking to log in again.
No matter how many times I relogin when I come back they are all logged out.
It does not seem to affect the Adguard doing its job as monitoring online I can see it is filtering.
Why do all the VLANS and Parental Contol log ins alway log out?
CC
I have the same on GT-AX6000. Did you buy an additional plan? On the free one, I have a maximum of 2 weeks and the monthly limit is used.
Free right now, I would go for lifetime if I knew it was worth it. What do you think?
Does not seem to be as effective on the Firesticks, youtube still showing the adds. Same for you?
I have Adguard DNS filter and Popup activated for Blocklist. Also have Hagezi's Pro +++ Blocklist. You?
CC
I am at 49K in less than 1 day! with 300K limit mine will last a week. What happens after you reach the limit? Does it still block but just dosen't register the hits? or does it stop blocking completly?
CC
CC
Well I an answer my own question the blocking stops. Whats the use of bothering if in a week its basically ineffective.
CC
in my opinion it's not worth it, the ads still appear, less, but they are there all the time. Browser blockers are more effective. YT is rather hard to block.
I just opted in for the free 1 month personal trial. It is much better, 10 million monthly requests. I have 6 filters going and average about 100K requests a day. That would be 3 million a month, way under the limit. So far so good.
