scottydog454
Hi All,
I am moving into a new apartment and am getting married, so this is the time to buy my goodies and do it right the first time. I understand VLANs to a small enough degree that I am certain that I will be getting a GS-108T smart switch and that I want my wireless to be AFTER that switch, on its own VLAN. I don't want wireless accessibility to my wired computers where I bank online, especially in an apartment where so many people will be within range. Because of this need, I don't need a wireless router - just a wired one and an AP or wireless router as an AP plugged into that switch. However, it's not easy to find a wired router with Gigabit LAN ports on it that isn't a newer wireless router anyway. I am favoring Netgear mostly now since their quality control seems to be back up to par and Cisco/Linksys has dropped (but starting to get more favorable reports). Here is my question. Is there a different way to do this other than what I am thinking of here:
I am familiar with Tomato, DD-WRT, etc and it seems like some will allow VLANs, but it's a moot point if I need a second wireless adapter to plug into that VLAN port.
Are there any errors in my logic or suggestions on an alternate setup? It seems that the router is the wishy-washy point in my topology since I need a more expensive one for Gigabit RJ-45 ports and don't even need the wireless, but a pair of 3500L's would probably serve me well with that GS-108T. Tim seems to like his E4200 experiences, though...
NOTE: Why are APs more expensive, by the way? Is it a POE thing? It makes for sense for a consumer setup to get a solid wireless router and disable DHCP. My wired speed is far more important to me, but since I'm buying new equipment I may as well do it right the first time.
- CABLE MODEM: (provided by Comcast. If it's not Gigabit for the WAN port, I will buy a Motorola SB6120 SURFboard DOCSIS 3.0 later on)
- ROUTER: Netgear WNR3500L = $70 (Amazon)
- SWITCH: GS-108T = $99 (Amazon)
- WIRELESS: Either a 2nd 3500L or perhaps I'll splurge and get a 3700 or 4200 = $70, $130, $150
