lopperman
Disclaimer: I'm by no means a security expert, and I acknowledge that some of the issues I found after installing AdGuardHome could be caused by my own configuration mistakes, or might have nothing to do with AdGuardHome.
I installed AdGuardHome today (version 1.9.3, via amtm). I'd been monitoring the output, and making adjustments to dns block lists, and generally looking around in the AdGuardHome settings. Something caught my eye when I was reviewing the Settings --> Client Settings. Some non-local ip addresses where showing up. Specifically: 167.94.138.178, and 66.132.153.155. Both of those resolve to census-scanner.com. What was confusing isn't that they were trying to 'knock on my door', but in fact they were accessing the locally running dns server that is installed with AdGuard.
Apparently, when AdGuardHome was installed, it was available from the WAN and allowed incoming UDP/TCP traffic on port 53. I don't believe by default that should ever be allowed, and and at least for my home network, I never need my local dns service to be available from the WAN. I fixed this issue by blocking incoming UDP/TCP port 53 for WAN traffic. It appears that AdGuard home ships with 0.0.0.0 as the default bind address for setup. It's possible that there's an assumption that the default firewall would block unsolicited WAN traffic to port 53, but in my case (I have a public ip that gets assigned to my WAN port from my Spectrum cable/modem), it was wide open. There's not legitimate reason I could find to expose your local dns service to the wan. It should only be needed for your home devices, or devices connected via VPN (if configured).
In my case, adding explicit drop rules for port 53 from eth0 (WAN Interface), solved the problem. (also added to /jffs/scrips/firewall-start to persist across reboots).
After I did that, I decided to dig a bit deeper, and found that AdGuard Home Web UI (which I'm running on default port 3000), was also exposed to the WAN. I blocked that by adding a drop rule for TCP/UDP Port 3000 from the WAN.
Probably unrelated to AdGuard Home, I also found that Port 21 (FTP) and Port 9999 (infosvr - known ASUS vulnerability), and Port 202 (what I running for local ssh only) were also open to the WAN, so I added drop rules for those as well.
Wondering if anyone else has had similar experiences
