Solved Ai Nodes dropped off and now I can't re-add them
Demon4231
A few days ago my power flickered a few times and the two nodes I had connected via ethernet dropped off the AiMesh. I tried to re-connect them, but they fail to add every time I try whether it's through WiFi or through ethernet. When adding the nodes it gets to about 65% then fails and gives a few reasons why but I've gone through each one and nothing seems to work. I've tried factory resetting all of the devices and tried a combination of firmware versions for each node and for the main mesh node.
My main mesh node is an AX86U and the two other nodes are an AX1800S and an AX56. If I setup the AX1800S as the main node I can add the AX56 to it as a node, but I can't add the AX86U as a node which make me believe that its a firmware issue or something along those lines. I've had the setup working fine for about 6 months without issue but now I can't figure out what's wrong. Does anyone have any ideas what it could be?
Nodes
- AX86U (Main)
- AX1800S (Node)
- AX56 (Node)
What I've tried
- Factory resetting all devices
- Connecting through ethernet and WiFi (within 3 meters)
- A combination of stock ASUS firmware versions
Did your main RT-AX86U auto update to Asuswrt 388_24231 by chance?
I don't think so, I would usually check to make sure the current version would show the one I installed. Currently the AX86U shows I have 3.0.0.4.386.49447 as the firmware version.
3.0.0.4.386.49447
Old and with bad Wi-Fi. Asus fixed it back then quickly with a new firmware release. Any particular reason you don't keep your main router up to date?
I have kept the firmware up to date but I've been going through almost all the older versions to see if any of them would work, and that was just the one I was currently testing.
After messing around I found a few things. For some reason DHCP isn't working for anything wired, and if I enable then disable WPS a node will reach 100% and then fail. I'm not sure if that's just a bug or not, but it seems odd.
I managed to figure out my issue. I have an access point on my network that was acting as a DHCP server. I have no idea why it started doing that but after disconnecting it I was able to add both of my nodes pretty quickly and without having to downgrade any firmware.
