AiMesh - connect to closest node
JohnD5000
I have some AIMesh nodes, my devices are connecting, and staying connected, to further away nodes. If I disconnect, and reconnect the WIFI, I then usually connect to the closest node.
Are there any settings I can change so that the devices will connect to the closest node or change to the closest node quicker?
Once your AiMesh is up and running and settled down with all nodes broadcasting their SSIDs, do your wireless clients BOOT UP and connect to the nearest node? If so, that's as good as it gets.
OE
This may happen when the clients are too close and the signal is too strong. AiMesh doesn't have much wireless tuning options, you have to reduce the number of nodes or spread them out further away.
