AIMesh Lan Speed halfed
The problem isn’t internet speed. Is lan speed. I have all wireless or wired card that are almost 2900 Mbps.. if they are connected through gigabit Ethernet I have a bottleneck in it and the lan speed must be about 100mb. No? Now I make another proof. I connect router and node with Ethernet cable and then I try to transfer a file from Nas to Pc wireless and then, I connect also pc wireless to node with Ethernet and make proof...
I hope that if I connect all with Ethernet cable the speed should be maximum, no?
Inviato dal mio iPhone utilizzando Tapatalk Pro
i don't quite understand what your setup is here
but to my knowledge both aimesh router and node are dual band
if they are connected using a wireless backhaul you speed will be reduced about half due to both routers radios doing twice the work
talking about link speed from a nas over an router to the main router using wireless backhaul results vary
if the nas connected to a router or node using ethernet for the transmission you should have no bottle necks
try using a different cable or ensuring the ethernet port on both devices support gigabit base-T (1000 MBPS)
nas -> router \\wireless backhaul\\ node -> pc
is a bottleneck, or any configuration similar to this using a wireless backhaul in the middle of this connection
nas -> router or node -> pc
shouldnt be any bottlenecks, devices should run at full link speeds
This is a five-year-old thread and the RT-AC86U mentioned will probably have died by now!
