AiMesh Node 2 Not updating firmware
js28194
Hello, I am adding a second AX58U as second Node to AiMesh. It added as a second node just fine, however, it will not update to the latest Merlin. The progress bar does keep moving forward to 100% and says it is complete, but it also states that it failed in the same dialouge box. You can see below the conflict.
Should I update to latest ASUS first then try again? Never had this issue with Node 1.
There is no need for the nodes to be on Merlin. In fact, most recommend Asus firmware for the nodes.
When I’ve had this issue I’ve rebooted the node a couple of times until it took. Worth a try :-)
Yeah, I have tried like hell. Even re-downloaded the same firmware from Merlins site, ensure MD5 / SHA256 matched. No dice. Even reset device, via reset for 10 seconds, setup as a router and GUI reset and also WPS + Power button reset. Nothing.
Verify you don’t have the RT-AX58U v2 router as it’s not supported by Merlin only V1 is. You’d have to use GNUTON’s fork of Merlin which includes RT-AX58U v2.
RT-AX58U v2 would be marked on the back of the router. If no v2 then it’s V1 and it can use Merlin’s main releases.
THat was it. Thank you.
