AImesh node requests dhcp, but never receives one...
Pergola Fabio
Hi, running an AX88u, 3004.88.1 , one of my ac86u nodes, sometimes goes offline , at that point my syslog is flooded like these below, reconnecting cable doesnt work, rebooting the node doesnt work
only fix is to reboot my router? why is that?
Mar  1 08:49:33 dnsmasq-dhcp[2273]: DHCPREQUEST(br0) 192.168.0.2 24:4b:fe:be:7c:10
Mar  1 08:49:35 dnsmasq-dhcp[2273]: DHCPREQUEST(br0) 192.168.0.2 24:4b:fe:be:7c:10
Mar  1 08:49:36 dnsmasq-dhcp[2273]: DHCPDISCOVER(br0) 192.168.0.2 24:4b:fe:be:7c:10
Mar  1 08:49:38 dnsmasq-dhcp[2273]: DHCPDISCOVER(br0) 192.168.0.2 24:4b:fe:be:7c:10
Mar  1 08:49:41 dnsmasq-dhcp[2273]: DHCPDISCOVER(br0) 192.168.0.2 24:4b:fe:be:7c:10
Below log from a bit sonner before it goes offline
Mar  1 08:48:09 dnsmasq-dhcp[2273]: DHCPDISCOVER(br0) e6:1e:5f:c8:b5:70
Mar  1 08:48:09 dnsmasq-dhcp[2273]: DHCPOFFER(br0) 192.168.0.101 e6:1e:5f:c8:b5:70
Mar  1 08:48:09 dnsmasq-dhcp[2273]: DHCPREQUEST(br0) 192.168.0.101 e6:1e:5f:c8:b5:70
Mar  1 08:48:09 dnsmasq-dhcp[2273]: DHCPACK(br0) 192.168.0.101 e6:1e:5f:c8:b5:70 Pixel-7-Fabio
Mar  1 08:49:00 wlceventd: wlceventd_proc_event(685): eth6: Auth 6A:6E:6A:51:0F:21, status: Successful (0), rssi:0
Mar  1 08:49:00 kernel: br0: received packet on eth6 with own address as source address
Mar  1 08:49:00 hostapd: eth6: STA 6a:6e:6a:51:0f:21 IEEE 802.11: associated
Mar  1 08:49:00 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc 6A:6E:6A:51:0F:21, status: Successful (0), rssi:-73
Mar  1 08:49:00 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Mar  1 08:49:00 hostapd: eth6: STA 6a:6e:6a:51:0f:21 RADIUS: starting accounting session 9C808A05B4EA4CFE
Mar  1 08:49:00 hostapd: eth6: STA 6a:6e:6a:51:0f:21 WPA: pairwise key handshake completed (RSN)
Mar  1 08:49:02 wlceventd: wlceventd_proc_event(662): eth6: Disassoc 6A:6E:6A:51:0F:21, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar  1 08:49:02 hostapd: eth6: STA 6a:6e:6a:51:0f:21 IEEE 802.11: disassociated
Mar  1 08:49:04 wlceventd: wlceventd_proc_event(685): eth7: Auth E6:1E:5F:C8:B5:70, status: Successful (0), rssi:0
Mar  1 08:49:04 kernel: br0: received packet on eth7 with own address as source address
Mar  1 08:49:04 wlceventd: wlceventd_proc_event(695): eth7: ReAssoc E6:1E:5F:C8:B5:70, status: Successful (0), rssi:-74
Mar  1 08:49:04 hostapd: eth7: STA e6:1e:5f:c8:b5:70 IEEE 802.11: associated
Mar  1 08:49:04 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Mar  1 08:49:05 hostapd: eth7: STA e6:1e:5f:c8:b5:70 RADIUS: starting accounting session 1C633ECCC2577503
Mar  1 08:49:05 hostapd: eth7: STA e6:1e:5f:c8:b5:70 WPA: pairwise key handshake completed (RSN)
Mar  1 08:49:06 wlceventd: wlceventd_proc_event(685): eth6: Auth 6A:6E:6A:51:0F:21, status: Successful (0), rssi:0
Mar  1 08:49:06 kernel: br0: received packet on eth6 with own address as source address
Mar  1 08:49:06 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc 6A:6E:6A:51:0F:21, status: Successful (0), rssi:-61
Mar  1 08:49:06 hostapd: eth6: STA 6a:6e:6a:51:0f:21 IEEE 802.11: associated
Mar  1 08:49:06 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Mar  1 08:49:06 hostapd: eth6: STA 6a:6e:6a:51:0f:21 RADIUS: starting accounting session E278D786F361764C
Mar  1 08:49:06 hostapd: eth6: STA 6a:6e:6a:51:0f:21 WPA: pairwise key handshake completed (RSN)
Mar  1 08:49:18 dnsmasq-dhcp[2273]: DHCPREQUEST(br0) 192.168.0.2 24:4b:fe:be:7c:10
Mar  1 08:49:18 dnsmasq-dhcp[2273]: DHCPACK(br0) 192.168.0.2 24:4b:fe:be:7c:10
Mar  1 08:49:24 rc_service: cfg_server 1312:notify_rc update_sta_binding
Mar  1 08:49:27 dnsmasq-dhcp[2273]: DHCPDISCOVER(br0) 50:02:91:bc:ba:39
Mar  1 08:49:27 dnsmasq-dhcp[2273]: DHCPOFFER(br0) 192.168.0.65 50:02:91:bc:ba:39
Mar  1 08:49:27 dnsmasq-dhcp[2273]: DHCPREQUEST(br0) 192.168.0.65 50:02:91:bc:ba:39
Mar  1 08:49:27 dnsmasq-dhcp[2273]: DHCPACK(br0) 192.168.0.65 50:02:91:bc:ba:39 ESP_BCBA39
Mar  1 08:49:27 dnsmasq-dhcp[2273]: DHCPREQUEST(br0) 192.168.0.2 24:4b:fe:be:7c:10
Mar  1 08:49:27 dnsmasq-dhcp[2273]: DHCPACK(br0) 192.168.0.2 24:4b:fe:be:7c:10
Mar  1 08:49:28 wlceventd: wlceventd_proc_event(685): eth6: Auth 98:F4:AB:FB:9A:BA, status: Successful (0), rssi:0
Mar  1 08:49:28 wlceventd: wlceventd_proc_event(722): eth6: Assoc 98:F4:AB:FB:9A:BA, status: Successful (0), rssi:-65
Mar  1 08:49:28 hostapd: eth6: STA 98:f4:ab:fb:9a:ba IEEE 802.11: associated
Mar  1 08:49:28 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Mar  1 08:49:28 hostapd: eth6: STA 98:f4:ab:fb:9a:ba RADIUS: starting accounting session 86735683AA6163AA
Mar  1 08:49:28 hostapd: eth6: STA 98:f4:ab:fb:9a:ba WPA: pairwise key handshake completed (RSN)
Mar  1 08:49:28 dnsmasq-dhcp[2273]: DHCPDISCOVER(br0) 98:f4:ab:fb:9a:ba
