AiMesh Node (wireless backhaul) has extremely low DL speeds (0.11 Mbps)
Jellybean
So I've got two AX88U - one is the router and one is the mesh node.
My house isn't designed with technology with mind - as such, we don't have ethernet jacks anywhere and we have very limited coax outlets in odd places (for something like moCA) - my room, master bedroom, family room behind a hole meant for a projection TV that I can't get to on my own (so a wired backhaul will be the ultimate goal, but it isn't something for the immediate future).
Anyway, I followed OE's guide on setting up the AiMesh (thank you for that btw). Both router and node have the latest Merlin firmware, and the node is connected via 5G with good signal. But anything that is connected to the node has horrible signal. If a device is connected to the router (in the same region as the node), I get good speeds.
For example:
Device connected to Node - 0.11 Mbps DL / 11 Mbps UL
Device connected to Router (in Node region) - 186 Mbps / 8 Mbps
I have a Gigabit subscription with Cox.
It's not just one device. It's all devices connected to the Node.
I'm including screenshots of my router devices, AiMesh details, and modem (if that helps).
Ai Mesh details (signal is - 60 dB)
Connected devices (underlined are those that are connected to Node)
Modem - TM8402a (Cox provided Voice/Internet modem)
For example:
Shouldn't the device connected to the router yield better speeds on Gigabit ISP service?
Have you tried a speed test on a PC wired to the cable modem?
OE
OE
That’s my bad on wording.
I meant a wireless connection to the router.
I’m getting 650-850 a la Ethernet to router.
That's more hopeful.
Have you tried different channels despite the good backhaul signal?
Perhaps remove the node to reset it and add it back again.
Here, I would test with a 100m Ethernet patch cord backhaul just to see what I get at the node.
I'm not familiar with AX setup.
New routers? Perhaps try the node as standalone router to see how it behaves... could be DOA. If not right, re-flash it and try again.
OE
