AiProtection - Malicious Sites Blocking, no logs since 10/23
in2ndo
Not sure if this is the right place to ask. If not please point me in the right direction.
Running firmware ver. 3.0.0.4.388_24609-gca2277b on a XT9. Prior to October of 2023, there would be an entry under the AiProtection - Malicious Sites Blocking tab in AiProtection. there has been nothing since 10/23.
Any way to check it this working? strange that there hasn't been any blocks. I don't usually navigate to sites I shouldn't but I'm not the only one using the network. and there used to be at least one entry per month.
Edit to add. Is working.
TIA.
You can test it here:
You have to disable your Web browser's Safe Browsing first. Otherwise AiProtection won't register anything.
Current AiProtection signature is 2.394. Self updated last Wednesday. You may need to run an update check manually.
