amtm amtm 6.6 - the Asuswrt-Merlin Terminal Menu, April 06, 2026
amtm 6.1.2 is now available
  • Changed armv7l router packports repository to @garycnew only. The @maurerr repo is no longer used. If you have this enabled in ep, 6, disable it and re-enable it again to only use @garycnew repo after updating to this latest amtm version.
  • Some changes in the mount-entware.mod as suggested by GitHub user ran-dall. This adds a cleanup logic to remove /tmp/opt if it’s a broken symlink or directory.
  • Good news for AdGuardHome users on firmware 3006, the woes are over and amtm caught up to its recent updates. You may again use amtm to check for updates.
Thanks for the info, @thelonelycoder! I was wondering if @garycnew or anyone else might be able to please provide a quick screenshot of what this particular screen now looks like? I could use an updated one for TAILMON, and don't have an ancient dinosaur router to try this on. ;)
Mr. Lonely Thank You for your work!
amtm (current) is working well with zero issues.
Looking for my passport to verify what my real name is, but my wife Ellen says it was in the suitcase we lost somewhere on a vaction.
YOU were on a vacation? Tell us about it. Maybe there's a video or movie available somewhere?
What screen do you need? I have such ancient routers. In fact I count 7 ASUS routers to my right.
Thank you! Looking for the one where you can pick the alternative entware repo's, like Mr. @garycnew's?
And mine isn‘t Coder, though the lonely part still applies.
Don't worry AMTM users can once again bask in the glory of AdGuardHome update notifications. Meanwhile, I will still be @SomeWhereOverTheRainBow . Many thanks to @thelonelycoder for making this all possible.
Recently updated to latest version with no issues but I don't see ep,6, not sure if this is normal
Yours is an aarch based router. This option is only visible on ancient mips and old arm routers with discontinued Entware branches.
I'm using amtm 6.1.2 but I don't see the option for Adguard Home
I have installed Adguard Home v1.7.6 and wanted to upgrade to the newer version.
Any advice?
