nospamever
I read somewhere that YazDHCP can be installed without AMTM but is it better to install YazDHCP via AMTM interface. Is that right?
Any and all of the third-party scripts that amtm supports can be installed manually, except those that are coded dirctly for amtm by me. amtm is a helper software so scripts are simpler to handle for users not so comfortable with a terminal.I read somewhere that YazDHCP can be installed without AMTM but is it better to install YazDHCP via AMTM interface. Is that right?
Thanks, greatly appreciate your work.Any and all of the third-party scripts that amtm supports can be installed manually, except those that are coded dirctly for amtm by me. amtm is a helper software so scripts are simpler to handle for users not so comfortable with a terminal.
Thanks, last night I used the same link you provided to install YazDHCP using Putty. All worked well until I rebooted. Then I lost 128 manual IP assignment and it went back to 64. Somehow YazDHCP is missing from Asuswrt but I can still see YazDHCP in terminal.![]()
GitHub - jackyaz/YazDHCP: Feature expansion of DHCP assignments using AsusWRT-Merlin's Addons API to read and write DHCP assignments, increasing the limit on the number of reservations.
Feature expansion of DHCP assignments using AsusWRT-Merlin's Addons API to read and write DHCP assignments, increasing the limit on the number of reservations. - jackyaz/YazDHCPgithub.com
Welcome To SNBForums
