amtm amtm v6.7 [2026-Apr-11] - the Asuswrt-Merlin Terminal Menu
So how long has that been available? I thought I was just clueless when I upgraded and the directions said enter p, but
I didn't see a p option in amtm menu. So I went hunting.
Practically since amtm v1.0 or maybe even earlier.
amtm 6.6 is now available
  • Added option p to add up to four of your own personal scripts to the amtm menu to run it directly from it. Thanks to @BrimoXD99 for the push to get this finally done.
Is the black space before "p1" and "p2" expected?
(Not for me; I expected a green space, as is used for the also right-aligned two character selection "dc" right below them)
Intended, forms sort of a group with p. Same as the games section, if installed.
amtm 6.7 is now available
  • Renamed the following modules: Diversion, ntpMerlin, scMerlin and spdMerlin. During the update, you may see the old (lowercase name) and the new module file being downloaded. This is expected.
  • Corrected spelling in various files.
  • Correctly removes script name in au Automatic script updates file when the script is removed. Thanks to @visortgw for reporting.
  • Adds support for wr Wireless Report for AiMesh by @JB_1366. Welcome to amtm!
After long consideration and checking the download counts from my server, I have decided to no longer update the standalone amtm legacy version. The legacy amtm version remains at version 6.3, released on January 31 2026.
From now on, only the firmware built in amtm version continues to receive updates, it is included in Asuswrt-Merlin firmware since version 384.15.
Can I ask a question please about what "Adds support for.." entails for "xxx" means in terms of what is shown in the amtm menus?
e.g. I have WR installed (and amtm shows it as such) but it is not in the list of 3rd party scripts?
Does this mean it shows up as wr if you install it via SSH but it is not actually an option for installation via amtm, in the 3rd party scripts?
The i screen shows all other scripts available to install. It filters out scripts that are already installed.
Ah... thank you, makes sense. I should have remembered this.
And as you have noticed, amtm detects installed scripts and features that it supports automatically. This has been a coding choice from the very beginning of amtm development.
So script update email, and main menu shows Backmon red, MD5 update. Update menu and Backupmon both show I'm at the latest. I redownload the latest version in the app. Still shows red on main menu. Exit amtm and return. Now it is green! Weird.
A couple quick comments after updating 3rd-party utilities on about a dozen routers (all but one are remote) using amtm auto uupdate function:
  • Adding asterisk to indicate which utilities will be updated was a great choice!
  • Consider moving Automatic script update disabled in MerlinAU. message after utility in menu instead of before it. IMO, more intuitive as I read through list.
  • Great choice NOT to auto update entware.
Thanks for implementing this!
