Any luck with wireguard on RC3-3?
javo
I've been trying to use RC3-3 firmware to setup a wireguard client with my vpn provider. The connection with my vpn server is ok, but as soon as I enable the wireguard connection as the active one, immediately I am unable to connect with anything (site, server and so on). As soon as I disable that connection and activate an openvpn one, I could again connect with any server, I though it could be a dns problem, been trying several options, but still as soon as I enable any wireguard connection on RC3-3, my network goes down.
If I used those same wireguard settings on another device, it works fine, the problem have it only with my TUF-AX5400 with RC3-3.
Any of you have been able to set up a vpn client with the RC3-3?
Any help is appreciated.
