Any way to disable firmware auto-update?
muhsingyu
Hi guys,
Is there any method to disable firmware auto-update on AC86U? Or any way to change the value of "FORCE_AUTO_UPGRADE" to "n" in package.mak? Or any way to prevent the router from automatically CHECKING the available update of firmware?
Thanks!
You would have to recompile the firmware with the option disabled. There's no nvram value that can be set to disable it.
