any way to link aggregate 2 wan connections?
Symbiot
Hi
I have a fiber-router which is set up with lan1-3 as ISP controlled wan connection.. meaning it runs through their router and lan4 is bridged so I can control it as I want.. with what ever router I want..
So basically I have 2 inbound connections from ISP.
anyway to bundle them to get double the joy?
aaand.. as I am writing this.. since it's 2x 1000/1000mbps... then ... my router would have to support 2Gbit network ... crap..
hm.. any other ideas as to what I might use all this bandwidth for?
There are many multi-WAN routers. But they don't give you a 2 Gbps "pipe" from two 1 Gbps.
The total available throughput will be 2 Gbps. But the throughput for any given Internet session will be 1 Gbps. You get a benefit when you have multiple LAN clients competing for internet bandwidth.
You are also going to find that there are very few web sites/services capable of operating at a full, sustained Gigabit rate.
