Hi everyone,
I’ve developed a working solution for application-based VPN routing. The basic idea is to detect which application is running on a target device, and then automatically set a VPN Director rule to route that device’s IP through the appropriate VPN.
Let me break it down into sections.
First, install adb on your router (using opkg):
Once adb is installed, you can query the currently active app on the target Android device. For example:
On my NVIDIA Shield, this returns something like:
This lets you know exactly which application is currently active.
Enable only the rule that redirects the device to the correct VPN. In my case, UK
This works because I pre-created a rule named NVIDIA_WGC2 (via the Merlin web interface) that routes the local IP 192.168.1.125 through WireGuard2.
Finally, restart the VPN Director service:
I’ve been testing this with a script that runs every 3 seconds. it works quite reliably,but see cron advices here:
Sometimes apps check geolocation too quickly and may fail the first time, but usually succeed on a second run.
This allows you to switch regions on demand.
The first time you connect, you’ll have to authorize your ASUS router on the Android device. Once authorized, the router will generate keys in ~/.android/:
These keys do not survive reboots, so you should back them up and restore them automatically before connecting:
Backup (one-time setup):
Always Restore before connecting:
With this approach, you can dynamically route traffic based on the active app on your Android device. It’s flexible, scriptable, and in my experience works well in practice.
Step 1: Detecting Which App Is Running on a Device
As an example, let’s take an Android device.First, install adb on your router (using opkg):
ssh [email protected]
opkg update
opkg install adb
adb connect 192.168.1.125:5555
adb -s 192.168.1.125:5555 shell dumpsys window | grep mCurrentFocus
mCurrentFocus=Window{52bbc7c u0 com.nvidia.bbciplayer/com.nvidia.bbciplayer.BaseWebViewActivity}
Step 2: Updating VPN Director Rules
Once you know the active app, you can modify the VPN Director rule for the device (e.g., 192.168.1.125) and redirect it to the correct VPN.- Disable all VPN Director rules for the device. For example:
sed -r -i.bak 's/<[01]>([^>]*>192\.168\.1\.125>>)/<0>\1/g' /jffs/openvpn/vpndirector_rulelist
sed -r -i.bak 's/<[01]>(NVIDIA_WGC2>192\.168\.1\.125>>)/<1>\1/g' /jffs/openvpn/vpndirector_rulelist
service restart_vpnrouting0
Changing WireGuard Configurations on the Fly
If you run out of VPN slots, you can also dynamically change the WireGuard client configuration. For example:
#!/bin/sh
# Configure WireGuard client wgc5 on ASUS Merlin
echo "Configuring WireGuard client wgc5 (NORD - Canada)..."
wgc5_enable=0
service stop_wgc
nvram set wgc5_addr="10.5.0.2/16"
nvram set wgc5_desc="NORD - Canada"
nvram set wgc5_ep_addr="iphere"
nvram set wgc5_ep_port="51820"
nvram set wgc5_ppub="yourkeyhere"
nvram set wgc5_priv="yourkeyhere"
nvram set wgc5_aips="0.0.0.0/0,::/0"
nvram commit
sleep 1
service start_wgc
echo "Done."
Managing ADB Pairing Keys
For this setup, you’ll need ADB debugging enabled on your Android device.The first time you connect, you’ll have to authorize your ASUS router on the Android device. Once authorized, the router will generate keys in ~/.android/:
ls ~/.android/
adbkey adbkey.pub
cp ~/.android/* /jffs/bootsurvive/android/
/bin/mkdir -p ~/.android/
/bin/cp /jffs/bootsurvive/android/* ~/.android/
