ASUS AX6000 Cable Modem/Wireless Router *Combo* (CM-AX6000)
brianjenkins94
Hey all, I bought this:
ASUS AX6000 WiFi 6 Cable Modem Wireless Router Combo (CM-AX6000) - Dual Band, DOCSIS 3.1, Gigabit Internet Support, Approved by Comcast Xfinity and Spectrum, 160MHz Bandwidth, OFDMA, MU-MIMO
Which doesn't look like its explicitly listed as a supported device but I wanted to check since I do see GT-AX6000 listed as a supported device.
Anybody give this one a try?
Here's a picture of the interface:
which has staggeringly little configurability.
Custom firmware on a CM isn't an option since it downloads from the CMTS every time it boots. I doubt there's any GUI / feature updates to the side you can configure.
