Asus AX88u Strange behaviour after firmware update and main 2.4 ghz channel totally away ( GN 2.4 visible)
Arnold_K
My router rt-ax88u never had issues with this router until now.
Flashed Asus-Merlin 3004.388.10 alpha 1 no issues. After flashing Asus-Merlin 3004.388.10alpha 2 the issues occur.
My 2.4 ghz doesn’t come on.
Performed hard reset no result, at start up the 2.4 ghz wifi signal pops up and disappear.
Testing testing and testing no result.
Guest network created and the 2.4ghz GN works fine.
Creating 5 ghz guest network, 2.4 ghz network disappears.
Flashed Asus-Merlin 3004.388.10 beta one, no improvement.
I read a lot on SNB and I know there are radio issues with ASUS routers but the strangled thing is the following: the output of the wifi compared with my old RT-ac68u is very poor, and using a wifi scanner on my phone result into EDIGRAM as manufacture of my router ( never seen before).
(I am not able to place screenshts of these results, because the router I leave this disconnected)
My old router has to do now all the work (before I used this as a mesh-node)
Did some several flashes of older asus-merlin and asus original software but without result.
Anybody an idea what happening ?
