Funnyland123
Asus AX88U wireguard problem!
Hello, I have now bought an AX88U and also imported the latest original firmware, which Wireguard now also has.
So far so good: Now to the problem, I downloaded the corresponding config from my VPN provider and also installed it on the router. If I activate the Wireguard, it says "connected" but I have no internet.
If I take the same file and import it into the Wiregard app on the Imac, the VPN runs immediately.
Now I tried to enter it manually, but it had the same effect.
If I take a config from a completely different provider, it works right away on the router.
Does anyone have an idea what the problem is?
this is what the file looks like (of course the keys have been changed by me)
[Interface]
Address = 10.14.0.2/16
PrivateKey = gLJUg,mfgsRit+unSz+ölkjdföglkjödlfkgjlkdföogkj=
DNS = 162.252.172.57, 149.154.159.92
[Peer]
PublicKey = fJDA+OA6.d.dfg,,RcoHfC2d.kn.dfng.,mdnfg.,msdng=
AllowedIPs = 0.0.0.0/0
Endpoint = de-fra.prod.surfshark.com:51820
[Interface]
[Peer]
