Asus ax92 WAN limited to 100mbps
ams_sxi
I set up the router and was getting full 350mbps for 2 hours and now i only get 80mbps.
when i checked the status it now says WAN limited to 100mbps
how do i increase the WAN limit
Try a new cable. Different brand. Different length. Put an unmanaged 'dumb' switch in between the modem/ONT and the router.
You can also try fully powering down the router, leaving the power switch to 'on', and unplugging it from the AC adaptor. Leave it like this for at least 2 minutes or more.
Tried all that doesn’t seem to work. If it was the cable it would not give me 350mbps for 2 hours then suddenly drop to 100?
Anything is possible when using non-standard cable.
