ASUS AXE-11000 – No WiFi after factory reset / mtd10 gets detached
kleinerflo
Hello everyone,
I’m having an issue with my ASUS AXE-11000 router.
Since performing a factory reset, WiFi is no longer working.
Current state:
  • LAN works
  • Web interface is accessible
  • No WiFi networks are broadcast
  • Boot process takes significantly longer than before
  • After a reset, it can take up to 20 minutes until the router becomes reachable
I have already:
  • Installed multiple different firmware versions
  • Reinstalled firmware using Rescue Mode
  • Performed several factory resets
The problem remains unchanged.
Relevant log excerpt​
The following appears in the kernel log:
Jan 1 00:14:42 kernel: ubi2: attached mtd10 (name "misc1", size 8 MiB)
Jan 1 00:14:42 kernel: ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Jan 1 00:14:42 kernel: ubi2: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Jan 1 00:14:43 kernel: UBIFS (ubi2:0): mounted UBI device 2, volume 0, name "nvram"
Jan 1 00:14:44 kernel: UBIFS (ubi2:0): un-mount UBI device 2
Jan 1 00:14:44 kernel: ubi2: detaching mtd10
Jan 1 00:14:44 kernel: ubi2: mtd10 is detached
Additional information:
I still have an old configuration backup.
If I restore it, I can no longer log in afterwards.
Does anyone have suggestions on how to proceed from here?
Is there a way to reinitialize or check the mtd10 / nvram volume?
Any help would be appreciated.
That's probably because when you created the backup you had checked the box that said:
Click on this checkbox if you want to share the config file for debugging. Since the original password in the config file will be removed, please do not import the file into your router.
