Asus AxE 11000 router + Asus Ax11000 AI mesh issues
LM1982
The AXE model is attempting to use 6GH and 160Hz within 2.4/5GH however the Ax11000 doesn't have 6GH option. How do I configure the AXE to support the limitations of the older router?
I could make the older router as the primary, and new router as AI mesh access point, however this will then loose the new features I should be able to use otherwise when connecting directly to the AXE router.
The AXE can't find the AI mesh client with its default name after it was reset.
How come?
