ASUS behind multiple-NAT how to setting DDNS and open VPN
freemankkw
Hi there,
My router is ASUS AC-87U version 384.10.2 Just moving to new ISP lat week , they just provide private IP address like 100.66.xxx.xxx
My question is could I setup DDNS or openVPN with my router ? My router directly connect to ONT and WAN type is PPPoE.
thank you first.
Freeman
You could set up DDNS using the "external" method. But unless you can get your ISP to forward the port on their equipment you won't be able to connect to the OpenVPN server.
choosed "external" but same...
Sorry, I don't understand what you're asking. What is "same"? DDNS appears to have worked.
Hi Colin, I means even choose external or internal via "asuscomm.com" both display registration successful, Actually didn't worked. testing by IOS via 4G pls see following.
2019-04-25 15:00:00 EVENT: RESOLVE
2019-04-25 15:00:00 Contacting [103.96.xxx.xxx]:1194/UDP via UDP
2019-04-25 15:00:00 EVENT: WAIT
2019-04-25 15:00:00 Connecting to [xxxxxx.asuscomm.com]:1194 (103.96.xxx.xxx) via UDPv4
2019-04-25 15:00:10 Server poll timeout, trying next remote entry...
2019-04-25 15:00:10 EVENT: RECONNECTING
2019-04-25 15:00:10 EVENT: RESOLVE
2019-04-25 15:00:10 Contacting [103.96.xxx.xxx]:1194/UDP via UDP
2019-04-25 15:00:10 EVENT: WAIT
2019-04-25 15:00:10 Connecting to [xxxxxx.asuscomm.com]:1194 (103.96.xxx.xxx) via UDPv4
2019-04-25 15:00:21 Server poll timeout, trying next remote entry...
2019-04-25 15:00:21 EVENT: RECONNECTING
2019-04-25 15:00:21 EVENT: RESOLVE
2019-04-25 15:00:21 Contacting [103.96.xxx.xxx]:1194/UDP via UDP
2019-04-25 15:00:21 EVENT: WAIT
2019-04-25 15:00:21 Connecting to [xxxx.asuscomm.com]:1194 (103.96.xxx.xxx) via UDPv4
2019-04-25 15:00:30 EVENT: CONNECTION_TIMEOUT [ERR]
2019-04-25 15:00:30 Raw stats on disconnect:
BYTES_OUT : 406
PACKETS_OUT : 29
CONNECTION_TIMEOUT : 1
N_RECONNECT : 2
2019-04-25 15:00:30 Performance stats on disconnect:
CPU usage (microseconds): 56547
Network bytes per CPU second: 7179
Tunnel bytes per CPU second: 0
2019-04-25 15:00:30 EVENT: DISCONNECTED
BYTES_OUT : 406
PACKETS_OUT : 29
N_RECONNECT : 2
CPU usage (microseconds): 57883
Network bytes per CPU second: 7014
Yes. I already told you that wouldn't work.
Unless you can get your ISP to forward the ports from their address (103.96.xxx.xxx) to yours (100.66.xxx.xxx) this will never work.
Any way to do do it using ipv6? I have a isp where the ipv4 is private, but the ipv6 address appears to be public.
