ASUS Dual WAN - Direct Youtube?
David Porter
Hi everyone
I have a dual WAN setup, and I want to tunnel all Youtube traffic through my primary WAN.
I've found a list of Youtube IP ranges, and I've applied them to my Dual WAN setup like the following (Asus DSL-AC68U)
http://imgur.com/a/cKxRR
However Youtube still tries to connect via my Secondary WAN.
An important note- the IP directed to use the Secondary WAN is also the device I want to use Youtube on the Primary WAN. I put the Youtube IP routing above in the list in hope of this being a priority.
Any help would be great
I know how to do this on smb class router because they have a way to make certain applications 'stick' to a particular wan/lan/etc.
Besides the routing table, is there anything like this in the Asus?
I can bind IP addresses to a particular WAN.
That's why Im here- to find out if there is a way to bind youtube traffic to a particular WAN.
If I had the answer I wouldn't be asking :)
Besides attempting to bind the IP addresses the way you did, I don't think it will be possible.
Can you put in the dns names or does it have to be IP addresses?
I'm actually surprised it isn't working just the way you have it if your screenshot is what I think it is.
