Release ASUS GT-AX11000 Firmware version 3.0.0.4.388.23285
karateca
Versión 3.0.0.4.388.23285
70.75 MB 2023/05/31
New features:
-Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
-iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
-DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
Bug fixes and functionality modifications:
-Resolved the issue with login and password changes.
-Resolved the IPSec VPN connection issues.
-Resolved the Instant Guard connection issues.
-Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
-Fixed the issue where Traffic Analyzer sometimes couldn't record data.
-Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
-Fine-tuned the description for port status.
-Enabled DynDNS and No-IP DDNS to use IPv6.
-Fixed AiMesh preferred AP identification in site survey results.
-Updated timezone list for Greenland, Mexico, and Iran.
-Modified the USB application option text in dual WAN.
-Allowed WireGuard Server clients to access the Samba server.
-Fixed memory leak issue.
-Enabled the failback function when using the iOS/Android USB backup WAN.
-The ARP response issue has been resolved, along with the connection issue between the router and the ROG Phone 6 and 7.
-Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
Security updates:
-Enabled and supported ECDSA certificates for Let's Encrypt.
-Enhanced protection for credentials.
-Enhanced protection for OTA firmware updates.
-Fixed DoS vulnerabilities in firewall configuration pages. Thanks to Jinghe Gao's contribution.
-Fixed DoS vulerabilities in httpd. Thanks to Howard McGreehan.
-Fixed information disclosure vulnerability. Thanks to Junxu (Hillstone Network Security Research Institute) contribution.
-Fixed CVE-2023-28702 and CVE-2023-28703. Thanks to Xingyu Xu(@tmotfl) contribution.
-Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group - cse hkust contribution.
-Fixed the cfg server vulnerability. Thanks to Swing and Wang Duo from Chaitin Security Research Lab.
-Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.
Please unzip the firmware file, and then verify the checksum.
SHA256: 30a2d458aa07bbc52dd657861255e59b4ab7157257a36f82d99c0b454fc981d1
Link
I installed this firmware on release day it it was ok until yesterday where the router became unresponsive. I could ping all nodes (7 x ax92u) but I couldn't reach the ip of the master node (ax11000) and I had to reboot it. Weird issue and I couldn't see anything special on the logs.
Keep us posted, I took the plunge tonight (June 12/2023), came back up fast (too fast maybe, that concerns me) & connected right back with the AiMesh node, no issues there (that concerns me too!). Been a long time since I had a firmware update from ASUS that wasn't a nightmare.
Hi All,
Has anyone noticed this strange behavior?
The 2nd radio apparently has a problem with the 80 ghz bands.
I have 2 GT-ax11000 one main other is Aimesh node (Wireless connected on 2nd 5Ghz band)
But the control channels seems to be odd?
If i select a channel higher than 112 it will not work anymore, or after reboot it goes into auto mode with channel 100 selected!
I've never had the desire to mess with that control channel setting. Mine is auto & seems fine though I am only responding to say it is currently on 149 (>112).
It's not like messing around, but more due to much routers of neighbors are on the first 2nd band channels in reach of the clients but not of my router, so it likes to stay on channel 100, but the upper once are free...
I'll put the previous firmware back to see if i can select those channels on 80Ghz mode with AiMesh...
Since upgrading to this firmware I've noticed that the download master application does not adhere to the default VPN connection in VPN fusion like it did previously. I also don't see an option to select the router as an endpoint to have it use a VPN tunnel all the time. (this has never been an option afaik though) Any others notice this?
Do any of the devs have access to any leaked betas for AsusWRT @RMerlin
We were able to get a leaked AX92U frimware before this way, seeking if this is possible aswell.
