Release ASUS ZenWiFi BT10 Firmware version 3.0.0.6.102_38991 (2025/09/16)
fruitcornbread
Version 3.0.0.6.102_38991
57.27 MB
2025/09/16
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
Bug Fixes:
- Fixed abnormal client list.
- Fixed abnormal GUI behavior of Wireguard VPN.
- Fixed USB internet backup conflict with main WAN.
- Fixed abnormal WAN detection while AiDetection is enabled.
- Improved AdGuard DNS GUI issues.
- Fixed IPv6 related issues.
- Improved USB tether compatibility for pixel phones.
ZIP SHA-256 : EF9DDEE9F0D4662216ADD5F6AAA7E017E56E0ABE05BBAC12FE185576F9AE27E0
FW SHA-256 : 423683268085447c9b22546062ab68a3c5ccbb6ed34c4b984a2211dfc7ec0e41
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi BT10/FW_BT10_300610238991.zip?model=ZenWiFi BT10
Thanks for the update @gollumbird.
Flashed this today. Good so far. Looks cleaner in terms of Wireless -> Professional settings, and I'm not seeing those disturbing "THRSH 2048" log messages. Haven't seen any "smarthaul" messages yet, either, now that I think about it. Still seeing the "DEAUTH error -30" messages, though. On the other hand, I change the LOG_LEVEL variable to 5 from the default of 6, so the messages may still be there at lower severity level. Took some time for me to configure after the recommended factory reset. Getting my IoT devices back on the router was a bit of work. But at this point, everything looks good. One device that I have that wasn't able to join the MLO main network with the previous version is happily on it. Looks like they've smoothed off a lot of bumps that were sticking out *smile*.
So far so good, we'll see though. Got my fingers crossed that I don't have to revert *smile*.
I have kind of given up turning on fronthaul MLO on my Asus BT10. I have a few different variation of Samsung Galaxy S25 phones and can't seem to have a stable connection with MLO turned on. The newest firmware update is no exception. Not sure if the issue is with Asus or the phones.
Don't know either. I have a Samsung S25+ that's fine with MLO for my main network here. Lots of variables and differences between two different home networks, though.
No problems with the new firmware yet...of course, one day isn't really a lot of time *smile*.
Thanks. May be I will try to reset my BT10s because I didn't do it yet.
Well, the "THRSH 2048" system log messages have reappeared with this firmware, again associated with our Apple mobile devices. Really would be nice to know what that's about, but there's no information about this from Asus. Lots of questions about these messsages on the internet, though. Still no functional problems yet. Seems stable and fast so far. Apple devices are fine when in use, no problems with wifi with them.
Just one more note *smile*. I turned off MLO on my main network to see what would happen. What I've been seeing is that I've retained the great wifi speeds all over my house, in excess of 900Mbps on wifi-7 devices, and things look better relative to the number of system log messages. Which means to me that the mesh is spending less time on dealing with conditions that it finds that require log messages. I'm attributing the continuing excellent wifi performance to the fact that MLO is still in use with the wireless backhaul, which I also see on wifi 6 devices. I suspect that if I had higher speed than gigabit internet, turning off MLO on the main network would result in client speed loss. But with my paltry gigabit speeds, not seeing anything except smoother, less disturbed operation.
Fine by me, I'll leave MLO off on my main network for the time being, then. And continue to be happy about how good the MLO backhaul functions.
Yeah I keep turning fronthaul MLO on and off but with MLO off, I think the Asus "Smart Connect" takes over which at the moment is a more stable feature than MLO for my use case. For backhaul MLO works fantastically because at both ends Asus is in charge. For fronthaul MLO the jury is out because when the client gets multiple hands assigned it seems to choose the "slower" band more often than not. I have 3gbps internet so I can tell when it's connected to 6ghz vs 5ghz. I think with Asus at the moment the Smart Connect is pretty much equivalent to MLO so choose whatever is most stable. In future as both Asus and clients update their drivers we will see a more stable fronthaul MLO experience -- it's getting there slowly but surely.
