fruitcornbread
Version 3.0.0.6.102_37421
63.2 MB
2026/03/30
Bug Fixes and Enhancements
- Improved WiFi roaming behavior to reduce temporary disconnections in some scenarios.
- Improved roaming compatibility for certain client devices.
- Improved App Remote Connection stability in certain scenarios to prevent unexpected connection drops.
- Improved AiMesh onboarding reliability, addressing cases where the onboarding process could stall and fail to complete.
- Fixed an issue where the guest network client list might not display correctly in certain scenarios.
- Fixed an issue where Aura LED could turn back on after reboot even when it was manually turned off.
- Fixed an issue with Web history display.
- Fixed an issue where the app could not remove offline devices.
- Fixed an issue where specific IPv6 configuration flows could cause IPv6 connectivity problems on the main network.
- Fixed an issue where enabling System Diagnostics and staying on a specific page could cause repeated reboots.
Security Fixes
- Enhanced input validation and protection to reduce the risk of command injection and SQL injection.
- Hardened environment variable handling.
- Hardened protections around specific logging/command composition flows to reduce potential injection risks.
- Patched a command injection risk in a specific network diagnostic function.
We recommend upgrading to this version to maintain best protection.
ZIP SHA-256 : 3233A138FE1F06BD32623D42F92B69CE6B8D813AE6B189C96CF4471BEAFF68CD
FW SHA-256 : 5914F8EA71CFC213F917B2B5054A8728068A3E0A696F541858801B9668B29872
Download: https://dlcdnets.asus.com/pub/ASUS/...000_PRO_300610237421.zip?model=GT-AX11000 Pro
(You will need to copy the link and paste it in a browser for the link above to work.)
rog.asus.com
63.2 MB
2026/03/30
Security Fixes
ROG-Republic of Gamers | Deutschland | ASUS
Entdecke die Welt von ASUS - Alles rund um die besten Mainboards, Grafikkarten, Monitore, Notebooks und vieles mehr erfährst Du auf der offiziellen ASUS-Seite.
